- Flipped the heads over, all the valve buckets fell out!
- Cracked Seat Belt Fix
- Speedometer/Odometer
- DOH! There goes my rear Diff..
- HELP! 86 4runner 22re
- Got the heads off, need opinions (3.0)
- strange Water leak
- 3vze knocking help!
- 1990 T4R auto tranny slipping
- OK the Haynes manual isn't as good as FSM I admit it
- 22re hesitation/miss
- 1994 Toyota Pickup (4WD/Manual/V6) Wiring Harness question...
- Dashpot plunger travel
- 3VZE surging idle after warm up
- AP diaphragm leaking
- Coach seat to first class
- 93 4 runner tranny problems after changing oil?
- 1991 Toyota pickup rumble from front end
- Down to the heads, dang exhaust manifold won't come off
- '94 Toyota 4x4 4cyl - erratic idle!
- Aftermarket temp gauge
- 90 2 wd question
- Testing A/c clutch
- Sudden loss of power
- Lower Control Arm R&R. Remove torsion bars?
- 1993 Toyota Pickup Clutch
- Maker Option vs Dealer Option A/C Wiring
- Idle High After Rebuild. Idle Adj all the way in..
- Easy (-ier) Remote Starter Switch
- Testing an Igniter
- need help!!!!
- Chain Rail - need to know
- Overheating, but I don't think it's a head issue... HELP!
- stumped by code 52.
- 1KZTE black smoke, excessive fuel consumption
- where is this check connector ?
- Fuel and spark but no fire
- Differential bearing size?
- 89 4runner and some front end concerns
- Download-able Factory Service Manual
- Broken Oil pressure switch question
- 91 Pickup problems.. Won't stay running after rain.
- Help with engine gaskets!
- 87 22RET Turbo EFI exhaust manifold
- fuel tank leak!
- erratic idle 22re
- Rebuilt 22re temp
- where to find a dashpot?
- Shopping for new wheel bearings and suspension. ('91 PU 22RE)
- Engine and Transmission Mount Replacement
- Best replacement engine
- lift truck 2.5".. new shocks?
- Headlight Brights don't work with switch - advice?
- Torsion bar!!!
- Rear axle/ brake question 91 4X4
- 1988 4runner 63" chevy spring
- Doing a gear swap and have some ?
- Aux air valve question
- Timing Adjustment
- am i the only one with pressed in leaf spring bushings?
- 88 Toyota puttering 4th gear
- fender removal
- interesting brake problem...
- Weird Bucking
- 3vze coolant pipe under intake
- Painted my truck! Pics inside
- Engine Re-asssembly and install
- please help
- Dash board replacement.HELP
- 90 4Runner v-6/MT transfer case removal by itself
- 22 RE timing kit.
- Green plug on top of 22re
- Need help! Oil leak.
- 22re rebuilt now bad gas mileage
- Whats it worth? Non-rununing 95 4x4 Pickup
- 1995 4runner coolant overflow cap orientation / position
- NEW EXHAUST 91 pickup
- Failed emissions, Hi NOX and CO need ideas
- just installed my body lift
- 1992 Rear gate not latching ARG!!!
- WTB: Rear Window for 1986 4Runner
- Trail Gear Problems... Assembled 3rd with ARB Locker
- Fuel pump not getting power
- 1993 toyota 2wd 22re??? ignition?
- Brakes for 1990 Standard Bed pickup
- 22RE Flamethrower injector review
- 94 p/u tcase/trans shifter bushings?
- Door skins ?
- Fuel tank drain plug?
- 22RE Air/Fuel ratio test
- New (to me) 89 Toyota Pickup with the 3.slow
- Changed coolant and not overheating
- PleaseHelp!! Were getting closer!!! 93 3.0
- Negative terminal ground
- 3.0 throttle body
- Looking to Trade next week for 89 4runner
- Please Help!!! 93 4runner 3.0 Emergency
- Front main?
- Overheated, now leaking coolant. What's this part?
- What does this sound like?
- 1993 Toyota Pickup Headlight Issues
- 89 Toyota 4runner ECU
- 1987 22R-TE Runs rough after changing head
- Help with Ball Joints
- 87 22r 4wd issue. Any ideas will help!
- 5th Gear Vibrations
- Swappable Parts
- 87' 22re won't run for more than 10 seconds
- Porsche 944 Wiper Delete Plug
- spindle/hub interchange
- 95 T100 DX stalls when accelerating
- Iso 4runner parts
- Auto to manual swap
- best place to buy on line
- A skip on #1 cylinder
- Tranny to block issues
- Am I going crazy?
- 94 rear differential
- 94 4runner rear window sticking on one side.
- 1986 4Runner Turbo 22rte AAV Coolant Elbow Part Number
- 3D Printed 22re
- 1990 22re pickup coolant hose help!
- 91 Toyota Pickup 22RE Idle very low only with AC on
- Bench seat to Bucket seats
- Tried fixing code 52
- few questions on 4runner parts interchange
- tboned ifs problems
- what is this?
- a340h trans problems
- Extra oil port
- Question on factory audio
- Custom Shell!
- @#%&@@ help 89 3.0 pickup
- Name this plug
- 93 Toyota pickup 3.0 v6!!!
- Two questions
- 22re heater pipes
- Truck will not start when warm.
- vibration under load or going uphill at 45-50 MPH
- '89 3VZE mis-fire
- Engine losing spark intermittently?!? 1991 22R Pickup
- 94 sr5 pickup v6
- Why Does My 4runner die when I unplug VAFM??
- Code 11 and more
- Rear wiper arm
- 87 4runner sr5 speedo/tach question
- 22re Head Gasket Issues
- code 22
- Cam shaft
- AC Clutch question
- Does the dual-stage thermostat benefit later model trucks?
- 22RE Gas Mileage
- so my e-brake broke today...
- Need help with 22rte starting issue.
- Fuel system cleaning
- 3vze #1 Tensioner Spring Bracket
- Pickup and 4Runner Driveshaft Lengths/Types
- 86 22re mods+302 swap question
- 1991 4runner
- 1992 22re injector leak
- 3.0 starts won't stay running.
- 22re. 94 4*4
- 87 pickup loss of power and dies
- 1995 4Runner question regarding shocks and gear shifter
- 94 22re
- Front differential questions????
- 87 4Runner Towing Capacity - Small camp trailer (Shasta/scamp)
- Strange issue after head job 22R-E
- Under powered truck, too small of an exhaust???
- pickup rear glass interchange?
- help with tranny issue...
- 1990 Pickup brake line help, please!
- Check engine light
- 90 4runner 3.0 sputtering?
- 3.0 egr
- replacing my kickdown cable today, i have a few questions
- Replaced rubber brake lines...
- Clean rear bumper with integrated hitch?
- Coolant leak / aftermarket or factory thermostat?
- Swappable parts
- Sad day 22re
- I need some news ideas on a unique missfire.
- dif crossmember bolt torque
- sputtering dying no idle problem
- Doors hard to close with windows up
- Upgrading Battery + Wire to Fuse Box 80A
- '95 4Runner wont run after plenum removal
- Rear tires spin out
- 87 22re Sputters/shakes/ and stalls
- intake clean out
- 94 pickup 4x4 wheel and tire advice
- Power Steering belt replacement
- 1995 4Runner wire harness
- Broken Valve Spring
- Need 1994 p/u 22re pinout
- Stuck leaf spring bolt
- Temp Gauge
- 94 ifs steering stabilizer
- 87 4runner rear wiper - How it goes?
- 1988 Toyota Pickup 22R engine stumbles when breaks are pumped
- 93 Truck 4x4 lurching and weird things. Please help! Marlin clutch issue?
- Ready to get started
- Please Help !!! 93 3.0 4Runner !!!
- 87' Battery light and Brake light and other electrical issues HELP!
- IFS "rebuild" protips?
- Part Number for torsion bar bolts 1995 4R
- 1995 Engine Swap ANYTHING but the 3.0L!
- Rattle in gear selector lever
- best shocks for a 2in. lift
- Backfire issue need help
- Zuk Mod Questions
- Installing a 87' 22re in a 94 pickup ??'s
- Differences between a 87 std cab and ext cab
- A340 H Automatic Transmission Fluid path
- 93 4runner solenoid and check engine code
- What is this wire for?
- a304h trans problem, everything has been done, help!
- Door Panel Schematic
- 2nd gen pickups build specs and pictures
- 3VZE Running Issues
- 94 4runner Power Steering Issues
- Engine knock?
- 1992 4x4 truck
- best and cheapest five inch lift for 87 4runner
- Tool box that fits under/behind rear seat on a reg cab truck . . .
- loose gear selector 90, 4runner
- 90 4x4 v6 automatic problems
- 94 pickup head gasket but compression is okay
- 22re intake manifold stud specs
- 90 runner running like crap!
- problem staring my 87 22re back up
- strange problem starting 87 22re
- Joining the "Won't Start" Club. Meh.
- Please help! 1993 3.0 4Runner 3vze
- Help Identifying Wobbling Pulley 93' 4x4
- 22re rebuild
- 91 3.0 sr5 pick up loss of power up hills 3rd and 4th gear and ˟˟˟˟ty gas mileage?
- 90 toyota pickup 3.0 hesitating?
- 88 4runner Cowl Removal
- 22RE stalling when at opt. temp - What is going on!?
- Where to find carburetor needle seat filter
- Dash Gauges, Short?
- Safest high speed in third gear?
- need more power out of my 22 re
- Hard Steering
- Bj lift
- Ect ecu??
- 302 in 86 4runner
- Dashboard nut behind glove box, what size?
