1987 22R-TE Runs rough after changing head
Old Mar 18, 2015 | 08:05 PM
franssell's Avatar
Hello,
I recently changed the head and head gasket. The truck ran fine for about a month but started running really rough.
I changed the spark plugs, wires, cap and rotor just before the head gasket blew. I also changed the PCV valve and checked the timing and its all good.
I'm at a loss as to what to check next.
Any help would be appreciated.
Thanks,
Old Mar 18, 2015 | 09:21 PM
Shady Cadence's Avatar
Rough when? At idle? On accel? All the time? Moving, or not?
Rough how? Like chugging, dead hole rough? Or more sputtery, stumbly rough?
Old Mar 18, 2015 | 09:43 PM
franssell's Avatar
All the time, more of a stumbly rough.
Old Mar 19, 2015 | 03:19 AM
Ignition issue. Best found by viewing the ignition pattern on an ocilliscope. You may want to defer this to a shop, if nothing else to minimize the parts you buy. See what they say, check back here.
Old Mar 28, 2015 | 05:14 AM
franssell's Avatar
Took it to a shop and they hooked it up to a oscilloscope and they learned that it was only firing on two cylinders. My wire harness to fuel injectors was really tight, so when reattaching the connectors two wires broke over a months period after replacing the head gasket. Changed two connectors, runs like a champ now.
Old Mar 28, 2015 | 05:16 AM
franssell's Avatar
Good call on taking it to a shop by the way! Thank you!
Yont283
Sep 23, 2022 08:06 PM
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
