Fuel and spark but no fire
Old 03-28-2015, 04:38 AM
noflyzone's Avatar
#4 cylinder not firing. 86 22re. Rebuild using engnbldr head and kit. Rebuilt spark plugs from Mr. injector. TPS adjusted to spec. Timing set to 5 degrees jumped. I see spark and wet spark plug. I hear fuel injector ticking with stethoscope.
Compression test next. I just don't have the right fitting for this head.
Any other ideas?
Old 03-28-2015, 06:48 AM
Staff
Terrys87's Avatar
I have seen a coil send spark to the plugs and still not fire. I suspect the fire is just to weak. I would check the Primary and Secondary on the coil. Haynes Manual has a good check for the coil.
Old 03-29-2015, 07:03 AM
noflyzone's Avatar
Can't believe it ran at all. Wires were 1-2-3-4 instead of 1-3-4-2. Timing was 180 out.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Doug4320
03-24-2018 10:11 PM
Hiluxtrucha
07-22-2015 10:00 AM
Sandman
07-14-2015 12:36 PM
Quick Reply: Fuel and spark but no fire
