88 Toyota puttering 4th gear
Old Mar 23, 2015 | 10:39 AM
auscal's Avatar
I have an 88 toyota truck with a 22r, on the way to work today about half way through my drive it starting puttering in 4th gear, low to middle of 4th gear, but didn't do it in any other gears and once i got higher in 4th it wouldn't do it. Where should i start with this problem? Any ideas? spark plugs, fuel filter?
Old Mar 23, 2015 | 01:15 PM
PapaChulos4U's Avatar
Sounds like a fuel problem. Has it been hard starting? Like cranking longer than normal?
Pull the plugs and see if they are wet; if so, you are getting fuel just not a burn. Replace them if this is the case. If this does not fix it, then your fuel pump may be on the way out. This is what happened with mine (among dozens of other things).
Probably not a bad idea to replace the fuel filter anyway.
Old Mar 23, 2015 | 01:18 PM
EDIT: I meant to say pull the codes too, that may help.
Gravel Maker
RuffStuff
Jul 6, 2015 07:43 PM
Gravel Maker
Vendor Advertising
Jul 2, 2015 12:57 PM
hexrain
Jun 27, 2015 06:17 AM
ACZR
Jun 23, 2015 07:55 PM
ranma21
Jun 22, 2015 11:55 AM
