need more power out of my 22 re
Old Mar 1, 2015 | 08:48 AM
shaddow0's Avatar
I have a 94 Toyota pick up with a 31s running 22 re it has a electric fan I have a intake a throttle body spacer I've done the exhaust headered high flow muffler its cammed is the next step injectors or what any advise would be great everything is lcenginering I have on it
Old Mar 1, 2015 | 10:48 AM
Teuf's Avatar
Unless you spend WAY more money its tough to get a big HP gain. Then again the beauty of these low power engines is they don't break.
Old Mar 1, 2015 | 11:29 AM
bswarm's Avatar
You might be able to squeeze a bit more power out of it by advancing the timing a few degrees. You'll probably need to use premium gas and have a functional EGR so it won't ping. I run 3 degrees advanced from specs, that's the limit for passing the smog check in California.
Old Mar 1, 2015 | 12:08 PM
wyoming9's Avatar
Red face
Need more power change your gears.
Do a swap to a more powerful engine.
Strip all the un needed weight out of the truck.
Horse Power gains in a 22R series engine are very expensive for little gain
Old Mar 1, 2015 | 12:22 PM
Teuf's Avatar
Huh.......5:29 and 33's = a million HP
Old Mar 1, 2015 | 12:53 PM
Schnayke's Avatar
Maybe just run it at a higher rpm. When are you shifting?
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
