Fuel tank drain plug?
Old Mar 20, 2015 | 09:28 AM
Shagool22's Avatar
Getting close to firing up my 87 4Runner that I just finished installing rebuild. Just got to add fluids and fire her up. But it's been sitting in the shop for over 15 years so I want to drain the fuel tank and out some fresh in there. My Haynes says there is a drain plug, but I can't find it. Do I need to drop bracket?
Old Mar 20, 2015 | 09:41 AM
Shagool22's Avatar
Figured it out. Gotta remove skid plate
Old Mar 20, 2015 | 10:54 AM
Terrys87's Avatar
I would not pull the drain bolt. It will have so much corrosion on the threads that it will score up the threads in the tank and leak. I have done that twice. You can seal the threads with Red Kote. You do have to pull the skid plate.
Old Mar 20, 2015 | 10:58 AM
bswarm's Avatar
I'll bet the in-tank fuel pump and fuel level sender are toast, mine failed letting it sit for about 5 years.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
kcaudill
Jul 20, 2015 12:06 PM
