PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Any help? Floor the pedal and engine wont rev
  2. 90-95 windshield trim issues
  3. High idle when cold, low when warm
  4. ideal suspension for 94 pickup offroad/ highway/ reliable
  5. Help with 22re engine mounts, and other misc. stuff
  6. Sloppy steering parts order list.
  7. cant start when I depress clutch pedal
  8. 90 pickup standard cab center console mod
  9. 3VZ-E propane conversion
  10. Battery incorrectly grounded?
  11. How I fixed my sluggish 22re
  12. 87 runner Ox sensor question
  13. Quick clutch install question
  14. 3.0 options
  15. n00b
  16. 4x4 diff swap help and questions
  17. Is it the head gasket?
  18. timing/vacum/ compresion tests....
  19. Loosing water still after headgasket replacement
  20. 84-89 Toyota/4runner custom bumpers?
  21. Heater valve and core pressure control
  22. 3VZE alternative exhaust manifold set-up...
  23. New to the forum/ which toyota to buy?
  24. help!!!!!!!!!! engine too tranny not mounting up right?!?!?!?
  25. 93 toyota pickup cranks but won't start
  26. 94 22re block question.
  27. Door Hinge quick question!
  28. fuel line part number
  29. '91 4Runner 22RE 4x4 rattle when off the accelerator
  30. Ball Joint question!
  31. 88 4x4 parking bake missing entirely?
  32. 1993 3.0 rebuild kit
  33. HELP -- 89 4Runner with 3.4 a total loss
  34. Couple questions
  35. Newly bought 88
  36. Speedo in my 87 pickup 4x4
  37. Quick cat converter help
  38. Code 12 Cranks/No Start 1993 Toyota Pickup 2wd 5spd 22RE
  39. custom built Roll Bars?
  40. Burned out glove box light?
  41. 89 Black toy build thread.
  42. Needing some advice with CV axles, ZUK mod, BJ Spacers, and new shocks
  43. 90 pickup Turn signal malfunction
  44. white smoke from exhaust (89 3.0 p/u)
  45. Could this be it?
  46. 94 22re changing head gasket
  47. 3.0 auto 4runner general question
  48. New carb, messed up vacuum lines??
  49. Which O2 Sensor?
  50. 87 4runner 22r runs rough
  51. AC compressor not on at idle?
  52. 87 Turbo 4Runner 22rte- Help with start up after sitting...
  53. Finished installing a rebuilt motor and it won't start
  54. the little yota that could...my new 92 2wd pickup
  55. Upgrading Front Shocks... which ones?
  56. 1989 4runner AC proplem..please help
  57. 31" tires for 1995 pickup
  58. Header Help!!!!!!!
  59. Throwing a code 12 ,25, and 26
  60. Rough Starting Idle
  61. add question
  62. Few '86 22R-E questions
  63. 22re Bucking under acceleration, runs great when let off gas.
  64. Cold-Air Intake from EBAY
  65. Help... Big 3 with battery swap
  66. gauge cluster stops working, running like crap, wont start
  67. 3VZE - Spring or hydraulic tensioner?
  68. Would *YOU* buy this housing?
  69. New leaf springs or weld used leaf spring pack?
  70. truck stalls when rolling
  71. Time to lift it! 95 4runner
  72. HELP! 92 4runner fuel issue
  73. Whats this part??? (3vze)
  74. $6 soft/bikini top!!!!! gotta check this out
  75. toyota pickup dies wont start fuel problem
  76. 3 dirt cylinders and 1 clean one
  77. Sunk the Pickup in water, wont start...HELP!!!
  78. here is my 88 4runner, almost done!
  79. Timing chain replacement- Can I skip pulling oil pan?
  80. '91 4Runner, 3VZE, Oil Leak
  81. 95 fuel pressure
  82. I've got a few questions after 22RE HG replacement
  83. Tach Adjustment
  84. DEA Tranny Mount...
  85. What else should I replace when doing my water pump?
  86. Lower ball joint replacement...
  87. Is this an option for changing trans fluid?
  88. 87 pickup down on power
  89. AIR FLOW MOD what a differance.
  90. 22re rebuild time. need advice on internals and other upgrades
  91. 22re starts but wont idle
  92. Wanting to avoid issues.
  93. New to forum... heres my 94 yota
  94. 92 yota running rough
  95. ABS ecu pinout/diagram
  96. TPS setting blues
  97. constant code 25!!!! need a real solution! searched every thread
  98. 22re runs hot after head gasket and multiple thermostats
  99. coilovers on rear of 86 4runner for clearance
  100. no turning signals or hazzards...
  101. AC Wire
  102. Lock-right locker making a "new" popping sound?
  103. 22re engine removal?
  104. Auto to Manual Help!! Starting...
  105. manual temp gauge install
  106. Silla All aluminum radiator installed...
  107. rims that dont rub???
  108. 1st Gen 4Runner: B-Pillar Badge Restoration?
  109. LED tail lights, need some help
  110. 22re AFM second opinion needed
  111. Efi swap
  112. Receiver or no receiver??
  113. vibration
  114. Welded in O2 sensor...thank you previous owner!
  115. 1987 4Runner Build Thread
  116. 3.0 highway overheating issue, water pump or radiator?
  117. MLS 3vze headgaskets
  118. 3VZE alternator pulley whine
  119. cabin filter???
  120. Lock Cylinder Jamming? This fix might work.
  121. ignition control mod
  122. fix a fuel gauge?
  123. About ready to set my 22re on fire
  124. summit elec pump 87' IFS
  125. Buying a used tranny & transfer case...what to look for?
  126. LED Blinker issues
  127. No start/power after HG replacement 22re
  128. Spark Plug Change/Nut Size 22re??
  129. 22re crank pulley movement - chirping sounds (video included)
  130. NWOR tri y header O2 sensor placement?
  131. 4runner tach question
  132. Brake Drum Removal
  133. Speedo Noise
  134. 87 Toyota pickup
  135. Best Gear Ratio for a 1990 toyota pick-up 4x4
  136. Gas Mileage again.
  137. Clock replacement from another make of vehicle
  138. Roll on paint??
  139. 3.0 V6 Engine Mods. Help!?
  140. Another Noob Question - Center Caps
  141. 87 4Runner Cruise Control.... :roll:
  142. Need A little help finding Parts
  143. 94 evaporator fitting difference
  144. 22RE turns off when coming to a stop HELP
  145. dang...got stranded at 7eleven - ign switch?
  146. Need help guys
  147. 1986 pickup rack
  148. Bought a 1995 22re truck
  149. Not getting power at the TPS
  150. Brake fluid reservoir interchange?
  151. 3vze low compression - Not starting.
  152. wierd LSPV noise 90 4Runner
  153. Mysterious 3ZVE coolant leek
  154. 22re Good Compression but Coolant in Oil
  155. Fuel leak... very frustrated and need help
  156. camry MAF questions
  157. 87 4runner 22RE injectors don't fire
  158. What is this part called??
  159. 1994 Toyota 4runner 2wd drive shaft part number?
  160. 22RE stops intermittently
  161. shackles to match bj spacers
  162. 95 4runner V6 3.0 3vze
  163. 1989 4runner 3.0 auto tranny problems
  164. Partial Paint Complete
  165. 87 Rough Ridin' -- Sound Familiar?
  166. 22re leaky rear main seal --- already has new seal installed!
  167. 1993 yota no spark need help
  168. 22RE engine help
  169. Code 51, how'd you fix it?
  170. Oil Leak Near Top of Head
  171. 3.0 V6 3vze Engine gasket kit ID
  172. cone washers on wheel hubs rusted solid
  173. 1991 22re trouble shooting coolant in oil
  174. Oil pressure sender help, 89 pickup.
  175. It's been a while, 86 re-birth
  176. swaybar disconnect
  177. Leaking Gas Smell
  178. 2 disasters and a FRANKENPICKUP: need help with engine swap: '88 to an '82
  179. Shroud Help
  180. head gasket time! (first timer here)
  181. Check Engine Light Problem
  182. Installed new clutch, not ticking noise
  183. 88 restored pics
  184. Seat Back Play
  185. Bum Bumper Blocks Access to Spare Tire Lower/Lift Mechanism
  186. will a 92 skid plate fit an 86
  187. Got a 1987 4runner tonight, my second rig!
  188. Jammed Upper Ball Joint
  189. 88 4runner 22re No Start
  190. Coolant temp sensor broke
  191. Fuse box help!!
  192. '87 ext Cab Pick up w/22R (carb) Fuel filter location?
  193. 90 4Runner 22re Knock
  194. Cab and engine/trans swap???
  195. Is this a bad intake gasket?
  196. Ball Joint Question
  197. top end tear down thinking bad valve 94 3.0
  198. Blew the head gasket again. project time
  199. 95 4runner Vibration
  200. 22rte wont idle (vacuum related)
  201. 22re won't idle after timing chain help!
  202. Condenser fan help?
  203. new guy with a question, pics of problem included
  204. Can't get broken head bolt out
  205. 89 Toyota Pickup Turn Signal Issue
  206. Rear axle pinion leak round 2
  207. Starter issues
  208. 22re runs like crap when its cold
  209. quick rear bearing help
  210. Ticking / Knocking noise
  211. 91 3.0l v6 knockin
  212. Cheapest Knock Sensor Fix. Code 52
  213. carb sputter
  214. 3vze diagnostic port terminal diagram?
  215. trans swap question
  216. 22RE starting/fuel problems
  217. 22RET vs 3VZE Radiator ????
  218. Metallic thumping while driving
  219. weird electrical problem
  220. 88 4runner sliding window wont lock
  221. 91 3.0 hard start after warm
  222. Timing belt questions
  223. coolant overflow from reservoir
  224. Wiring on auto to manual transmission swap
  225. Summer plans.
  226. How many O2 Sensors are there?
  227. panhard bracket question?
  228. 22re glowing exhaust manifold
  229. Problems connected? Advice please!
  230. 87 4runner pinout or schematics
  231. 22r putting in manual temp gauge
  232. Cool Weber 38
  233. 1987 4runner sr5 turbo dashlights go out when I turn headlights on
  234. Crack in drive shaft?
  235. So. Many. Wires.
  236. OBD1 software
  237. Opinion time! Freshly rebuilt 22RE sound...normal or not?
  238. bj-spacers done....
  239. Shifting Problems/Clutch ....?
  240. Bad throttle surge/Drop off at higher RPMs
  241. Lifter adjustment/valve tick
  242. A few tranny questions...
  243. AFM clicking.
  244. Oxygen Sensor Replacement
  245. Little Rock, AR - Toyota on the side of I-40
  246. Oil pressure light
  247. 3VZE Silicone Radiator Hoses
  248. 3vz coolant bypass pipe
  249. Truck was stolen, slightly chopped, then recovered. HELP
  250. "I got a headache THIS big, & its got W56 all over it"
