3vz coolant bypass pipe
Old May 26, 2012 | 11:27 PM
954x4runner's Avatar
Im almost done with my headgaskets. The coolant pipe that runs in the valley, under the intake manifold. Is there supposed to be a gasket where the pipe meets the block? I can't seem to find one on the online parts websites. Its weird cause when I removed it, it doesn't look like there ever was a gasket. Seems like there must be something cause if it leaks you would have to remove everything to get to it. Is it safe just to use rtv??
Old May 27, 2012 | 05:14 AM
rworegon's Avatar
There is no gasket there. The FSM calls for a bead of seal packing material (FIPG). I have used Ultra Black RTV (or similar) with no issues.
See page EG2-127, step 16:
http://www.ncttora.com/fsm/1990-1995...neme/cylin.pdf
Old May 27, 2012 | 08:55 AM
Awesome thanks sir.
Old Jan 24, 2021 | 04:07 PM
4runner4days's Avatar
@rworegon I'm a the same step of the HG replacement process. What about Permatex Ultra Grey or VersaChem Mega Blue? Do you think either of those would be fine for the bypass pipe gasket?
MasterOfNone
Dec 8, 2019 05:40 AM
93fourunnerSR5
Mar 31, 2019 06:58 AM
87roctruk
Dec 5, 2015 06:21 PM
DupermanDave
Oct 22, 2008 10:05 PM
rah1420
May 24, 2005 06:02 AM
