4runner tach question
Old Jun 10, 2012 | 07:06 AM
yuribarber's Avatar
I have a 89 4runner sr5 with the 22r engine. I had to junk it*tear*. However I bought a 94 pick before I did and started to swap the interiors. What I noticed was the 94 has no tach. Can I put the 89 cluster in and have it actually work or will I have to modify the cluster. Also when I removed it from the car I noticed a wire going to the cluster on the tach side.
Tl;dr have a 89 4runner tach and want to put it in a 94 pickup. Same engine and tranny
Old Jun 10, 2012 | 08:07 AM
justin_4runner's Avatar
u will have to more then likely move wires in the 94 harness to make it work. also in 94 didnt they have a electric speedo. and the 89 is mechanical. it does sounds like someone might of added a cluster for the tach in the 89 or like me had a grounding issue and the lights didnt work and that was the fix.
Old Jun 10, 2012 | 08:11 AM
yuribarber's Avatar
So how would I go about switching it over?
Old Jun 10, 2012 | 08:13 AM
yuribarber's Avatar
well judging by the cluster the Speedo is mechanical
Last edited by yuribarber; Jun 10, 2012 at 08:17 AM. Reason: looked twice fixed info
Old Jun 10, 2012 | 08:20 AM
yuribarber's Avatar
Also should note its in kms
Old Jun 10, 2012 | 09:12 AM
DeathCougar's Avatar
89 and 94 clusters are not interchangeable without MAJOR wiring modifications, as well as adding a speedo cable.
I wouldn't bother, its not worth the hassle
Old Jun 10, 2012 | 10:03 AM
Team420's Avatar
ya, just go to a boneyard and grab one. The swap from a 93-95 isa pretty simple job... plenty of threads here covering that swap...
Old Jun 10, 2012 | 12:30 PM
yuribarber's Avatar
Would a 94 base 2x4 have a tach built into the ecu?
Old Jun 10, 2012 | 12:55 PM
BMcEL's Avatar
You might be in over your head on this one.
Old Jun 10, 2012 | 01:14 PM
yuribarber's Avatar
Let me clarify is the tach reading off the coil or ecu?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
