Tach Adjustment
Old Jun 13, 2012 | 12:26 PM
axekick's Avatar
Tach Adjustment
I found that the tach could be adjusted with the speedo still attached by bending the little adjuster out a little. This way, if your speedometer is correct, you can calculate what the RPM should be at any speed and adjust accordingly. I made a little excel calculator to help with this. This calculator is to be used with your transmission in its 1:1 gear. You input tire size and rear end gear ratio. It goes from RPM to speed and the other way around. Let me know if it's useful or if I could make it more helpful.
https://docs.google.com/spreadsheet/...Ew1b1dhekkxM2c
zytra
Jan 24, 2019 03:16 PM
the_supernerd
Oct 1, 2015 09:20 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
dbollier123
Sep 29, 2015 05:23 PM
