Spark Plug Change/Nut Size 22re??
Old Jun 10, 2012 | 01:06 PM
Gregs94Toy's Avatar
Cool Spark Plug Change/Nut Size 22re??
Stupid question, but this will be my first spark plug change on this engine. What else besides wires and plugs should I change out? Good running truck, never any troubles just wanting to do preventative maintenance. Also, what size deep socket to pull the plug out with? Thanks, from a diesel guy with little gas engine knowledge.
Old Jun 10, 2012 | 02:42 PM
wyoming9's Avatar
Wink
You might want to include a cap and rotor .
You might want to use a spark plug socket 13/16"
Air filter he if you don`t change it with the oil.
might want some never seize for the plugs Dielectric grease for the spark plug wires.
For what it is worth I had miss issues till I started using Toyota wires.
Old Jun 10, 2012 | 02:52 PM
malteserunner's Avatar
Toyota cap, rotors, and wires. NGK plugs.
Toyota cap, rotor, and wires. NGK plugs.
Old Jun 10, 2012 | 02:58 PM
Gregs94Toy's Avatar
Do you have to set timing when changing cap/rotor?
Old Jun 10, 2012 | 03:03 PM
wyoming9's Avatar
Wink
No not most times!
Had a helper that decided he needed more room to work so he pulled out the distributor to change the cap and rotor.
Now that was interesting.
Old Jun 10, 2012 | 03:15 PM
Gregs94Toy's Avatar
Yeah cool ok, that's like pulling the motor out just to change the injectors. Hopefully the timing won't be an issue. I bought the truck a year ago now, haven't touched anything but oil changes, air filter, and brakes.Oh , and a few days ago my A/C belt loosed up from running A/C all day driving 85+ on a highway trip. But also only put about 10k on it in 1 year.
Old Jun 11, 2012 | 05:51 PM
Gregs94Toy's Avatar
Ok went with Borg-Warner wires and NGK plugs from O'Reilly. Old plugs were a different grade NGK btw..#3 and #4 plugs were totally corroded, amazing the truck still ran. Also did the fuel filter today as well. We'll see if the mileage improves now. Truck has a little more pep now.
Old Jun 11, 2012 | 06:18 PM
ksti's Avatar
Originally Posted by wyoming9
No not most times!
^^That's classic man lol. Do let him help you fill with fuel.
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
