87 Toyota pickup
Old Jun 9, 2012 | 02:52 PM
93tonkatoy's Avatar
87 Toyota pickup
My buddy has an 87 Toyota pickup 4wd 5spd with the 22r I believe. 2 barrel carb. it will not start. It has a brand new coil. Wires. Plugs. Cap. Rotor. Fuel pump. Fuel filter. It's getting awesome spark. It is getting fuel at least to the inlet side of the carb. But when you crank it and tap the gas and all that you get nothing. I pulled the new plugs and they didn't even smell like gas. I sprayed the carb with gum out and still nothing. Need help. Please
Old Jun 9, 2012 | 04:55 PM
TrikeKid's Avatar
What's it do when you dump a little gas down the carb?
Old Jun 9, 2012 | 11:25 PM
93tonkatoy's Avatar
Oddly. Nothing. I think the timing chain slipped a few teeth. Not too sure
Old Jun 9, 2012 | 11:54 PM
yotarover's Avatar
watery gas maybe. that was my problem. Although Im EFI not carb, I imagine it would result in the same.
Old Jun 10, 2012 | 12:35 AM
gooberclese's Avatar
If the motor spins and your getting gas through your carb but it wont fire I would check the timeing. The chain is pretty cheep and you may have the option of upgradeing to a dual row chain. Peace of mind.
Old Jun 10, 2012 | 08:12 AM
ratso's Avatar
I would check the igniter this box sits on the driver side and could be the problem.The distributer also has an electronic pickup that could be bad.
Old Jun 22, 2012 | 07:57 AM
93tonkatoy's Avatar
The coil is brand new. Gets plenty of fuel. IT turned out that the timing chain guides busted into like a thousand pieces and let the chain get some slop and slipped 8 teeth. When you rest the timing be sure that the cam timing mark is at roughly 1145 and the crank is tdc. Makes things alot easier.
Old Jun 22, 2012 | 10:51 PM
abecedarian's Avatar
Tried starting fluid?
Pulled the valve cover to make sure the timing chain hasn't broke, and the cam turns when you turn the crankshaft?
6th Gear
19
Dec 10, 2019 07:31 AM
Weidle
Jan 21, 2019 05:39 AM
Aleeex_u
Jun 5, 2016 06:52 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
