Seat Back Play
Old Jun 3, 2012 | 07:49 AM
CW5150's Avatar
Seat Back Play
Hi Everyone...my first of what I am sure will be many, many posts over the years.
I just acquired a 1990 SR5 4WD Xtra Cab to use as my daily driver. Truck I always wanted. Don't plan to modify it much, but I am sure I will have lots of questions.
I tried to search for this one, but couldn't find anything. The drivers side seat back has about 1/2" of play back and forth. Really not a big deal, but I keep thinking there must be a way to tighten it. I took the trim piece by the adjuster off, but the compression spring and everything else looks fine. So just wondering if anyone has ever solved this problem.
Thanks in advance!
Old Jun 5, 2012 | 01:30 PM
CW5150's Avatar
So I realize this is not a huge technical problem. It is just slightly annoying and seems like something that shouldn't be too hard to fix. I was thinking about replacing the recliner mechanism...until I looked up the part and it's $140 :O...and I don't even know for sure that would solve the problem.
Old Jun 5, 2012 | 02:13 PM
nieb15's Avatar
Try simply shimming the catch that holds the seat. Duct tape works well, but you will need to replace it if you use the seat a lot. Still a roll of $2 duct tape is a lot less than $140.
Old Jun 6, 2012 | 05:24 AM
CW5150's Avatar
Cool...thanks. I will give that a try. I need to take the covers off again and see how the catch works. I know there is a compression spring in there as well. If I figure out a fix I will post my findings.
bigjstang
Jun 2, 2025 03:56 PM
crashburnoveride
Aug 28, 2015 09:20 PM
icentropy
Jul 9, 2015 02:12 PM
Steezy96yota
Jul 6, 2015 10:00 AM
Suprarossa
Jul 6, 2015 05:21 AM
