1991 22re trouble shooting coolant in oil
I have a 1991 22re pick-up with 290,000 miles on it. Last summer i looked and I had oil in the coolant and coolant in the oil. I compression tested it today and all 4 cylinders had 170 psi. I thought with a blown head gasket i should have bad compression in atleast one cylinder. Could it be the timing chain cover?? If so do i need to check the bearing in the oil pan and what do i look for when inspecting them???
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
Poncho0206
07-10-2015 06:21 PM
