carb sputter
Old May 30, 2012 | 01:35 PM
white0311's Avatar
carb sputter
Just installed new electric fuel pump, regulator, and fuel pressure gauge. Cranks fine runs prefect for about 10 minutes when you give it gas it spudders and trys to cut off.the fuel pump is run to a toggle switch from the battery if that has anything to do with it.
Old Jun 2, 2012 | 12:14 PM
stevewaclo's Avatar
Hmmm.
Your subject line sez "carb" sputter but all the bits you described are in a Fuel Injection system. Also, you're pretty stingy with general 411. Tell us more about your truck and all will be forgiven, newbie!
Old Jun 2, 2012 | 01:07 PM
white0311's Avatar
It's a Weber carb. It runs fine until warmed up. Then sputters backfires and cuts off. I've finally broke down and took it to a shop
Old Jun 3, 2012 | 08:23 AM
stevewaclo's Avatar
Be sure to report back!
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
