truck stalls when rolling
Old Jun 14, 2012 | 09:13 AM
azredneck's Avatar
i have a 92 toyota truck 2wd with the 22re and 5 speed...truck runs fine at idle annd sitting still..when you start to drive the engine starts to stumble and wants to stall..first thought it was fuel issue...new filter and pump is with specs....found out truck has same issue in neutral rolling....with engine running in neutral,i can push the truck forward and engine starts to stumble, stop pushing idle goes back to normal...same with pushing backwards...truck still does it with the wheels off ground.....i unpluged the speed sensor and the other sensor from the tranny..no change...even bypassed the clutch safety switch..
im at a loss....truck is my daily driver so need to get this fixed...anyone have any thoughts?.....thanks a ton!!!
Old Jun 18, 2012 | 05:35 PM
azredneck's Avatar
Any body?....please help
Old Jun 20, 2012 | 02:09 AM
bfunkchubb's Avatar
So with the truck in neutral, you can physically push it back on forth and you still have the same issue? What about just with the clutch pushed in?
JF9243176
Oct 8, 2017 04:21 AM
stav
Jul 7, 2015 07:57 PM
94 Newbie
Jul 6, 2015 04:23 AM
Gamble_STi
Jun 27, 2015 07:54 PM
JF9243176
Jun 24, 2015 04:53 AM
