swaybar disconnect
Old Jun 4, 2012 | 06:38 PM
Mandy Tuning's Avatar
swaybar disconnect
anyone try this method?
Old Jun 5, 2012 | 02:30 AM
FourwheelinVT's Avatar
I saw those, but I want to make a pair of these soon.
Old Jun 6, 2012 | 06:24 AM
Zelephant's Avatar
Anyone have how-to's or parts lists to build those? Swaybar discos on 1st-gens have always been tricky.
Old Jun 6, 2012 | 02:24 PM
ToyoTech559's Avatar
i made a set using the op methods. the coller spacer deal sucks. it doesnt hold. they do work if you drill a hole and use a pin instead. i didnt try to mess with it more and just removed the sway bar completely. right away you notice a little more lean. but after a few drives, i got use to it and dont even notice they are gone. if you can, remove the sway instead. save the money for other stuff. it might be how my suspension is set up but i can still turn pretty aggressively and not feel like its gonna roll. also i had wheel spacers, 1.25 so that might have helped with 32x11.5 tires on 15x8 rims. now that was with my old set up.
now that i have Long Travel. it doesnt seem to sway as much as i turned up the torsion bars so that made it a little stiffer, less sway but still rode good because the arms have more leverage.
Gone Fission
Oct 7, 2015 12:42 PM
dbollier123
Sep 29, 2015 05:23 PM
JamesDINAN
Sep 22, 2015 05:37 AM
SCZIG
Sep 20, 2015 09:00 AM
justdifferentials
Sep 5, 2015 06:52 PM
