PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 [246] 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Catalytic smeels on warm up
  2. 12.5 to 15.4 mpg gain
  3. Valve cover gasket leak.
  4. Pic of my 90 4runner and my dads 02
  5. Bypassing AIR Tube
  6. 87 pu DASH REMOVAL how to?
  7. Piston ring order
  8. Cam Shaft positioning
  9. Parting out 1993 pickup 4x4
  10. Overdrive or Not
  11. tube bumper designs
  12. Tail light options?
  13. correct spark plug gap??
  14. Bigger Brakes: With Pics
  15. 91 to 93 Bumper Switch
  16. Torsion Bar Adjustment on 1st Gen 4Runner?
  17. need help, pictures and info on Kayline/STC 4runner top?
  18. Will an 85 trans work in an 87 pu?
  19. picture of shifter arrangement
  20. rebuild almost done what do you think of this 22rtec
  21. Leaking Front Differential
  22. 5 lug now want 6 lug
  23. tranny overheating?
  24. high beams don't work?
  25. determine this cooling system hose
  26. gears in a 90 4runner with auto
  27. 3.0 REBUILD PART PRICES (What I Paid)
  28. Need help with 3.0 downpipe flange
  29. Noises! need some help
  30. Vin # Question and Emission Question
  31. Found Speedometer cable cheap. Quiet and no more bouncing
  32. need help finding out what gears i have
  33. Motor Is In, Vacuum/intake/fuel Setup Needed!!
  34. help!!engine is acting weired??
  35. new motor still not running right
  36. Door hinges
  37. Anti Freeze spilled on 91 4 runner engine
  38. POSI rear
  39. 86 Shackle length
  40. Bushwacker Fender Install
  41. Sputter sputter smoke...bye bye gas
  42. Looking for this Front Bumper
  43. 4runner leafs on Pickup
  44. 22RE rocker arm shims
  45. High Idle post-headgasket (3VZE)
  46. Cv axles
  47. A little rubbing
  48. '91 radiator replace
  49. I say goodbye to my 2nd generation
  50. Spark plug Replacement now High Idle
  51. fender decals
  52. Roof cut-off, 2nd Gen.
  53. Identify this part for me...
  54. Trying to set up my front diff and. . .
  55. W55 Tranny difference from a W56
  56. blew a head gasket
  57. Thoughts on putting in a new OME suspension...
  58. ALMOST Dying while try to accelerate
  59. rear leveling coils on 94 4Runner
  60. 3.4 swap air intake problems
  61. coolant leak and misc ????'s
  62. can i change the timing cover without removing head
  63. brake light problems
  64. 95 4runner shimmy and shakes real bad
  65. October=Tune Up Time
  66. Speaking of new rear springs . . .
  67. 22RE compression ?
  68. 22RE Distributor Help
  69. Rear dent repair
  70. U-Joints?
  71. defrosters not working??
  72. Pizza Cutters for the Snow
  73. Cylinder Head/Valve Job
  74. Really loud vibration and squeek
  75. '87 4Runner Service Light issue
  76. Need an education on 3.0 cold start injector.
  77. W56 vs A340F Driveshaft
  78. Anyone in AZ have an extra V6 carrier?
  79. 93 3vze engine codes 14 & 71
  80. exploded views
  81. Marlin Crawler Install + x-tra(56K BEWARE)
  82. 3.4l swap into 1990 4x4 pickup
  83. Speedometer Not Working When First Starting Off
  84. 4 skin ...
  85. Check Engine Light
  86. questions on installing an sr5 gauge cluster
  87. 1989 pickup Speedo not working
  88. Speedo not working
  89. buzzing sound
  90. New Valve Job
  91. New fog lights (pics!)
  92. OIL LEAK help please
  93. Intake plentium studs 3vz?
  94. Camshaft break-in, need serious help
  95. New springs installed!
  96. ARB snorkel... How do I make it work with an EFI toy?
  97. ARB snorkel... How do I make it work with an EFI toy?
  98. Roof Mounted Spare Tire too Top Heavy???
  99. Roof Mounted Spare Tire too tipsy???
  100. worn driveshaft
  101. runs rough after rebuild head
  102. Where to Wheel?
  103. Front End Package
  104. anybody ever had there mud flaps ripped off?
  105. Stupid, stupid, stupid (I hope I found source of front end noise anyway)
  106. engine vin number
  107. Plug and Play megasquirt - Success!
  108. Brakes 89 pickup 4x4
  109. Keyfob
  110. thoughts on SAS companies
  111. Overheating, high idle, rough shifting
  112. Torsion bar adjusting bolts broken?
  113. What would cause a timing chain to break?
  114. How can a loose EFI relay cause a draw?
  115. broken rear leaf - replacement
  116. Going through Tie Rod Ends
  117. Setting up a 3rd Member in Western NC
  118. Deal Or DUD?(ebay ifs parts)
  119. 5.29's and 36's
  120. Axle swap?
  121. 1994 22RE Header????'s
  122. Good shop for engine rebuild near Denver
  123. LC Engineering Exhaust
  124. code 71
  125. Bleeding the coolant?
  126. A/C problem
  127. ok replaced head gasket still oil in radiator( help please)
  128. Body Rust
  129. Help, horn not honking
  130. 2nd Gen Runner in the Cold
  131. clearing codes
  132. Replacing Valve Stem Seals...a DIY Job?
  133. Steering wheel wobbles and shakes.
  134. Steering wheel wobbles and shakes.
  135. possible window tint fix -pic
  136. My Buddy Needs A New Landcruiser Motor
  137. 3rd gen bumper fit
  138. Fuel leak help needed
  139. Striaght Axle
  140. 3VZE Head Gasket Replacement
  141. What goes here?
  142. rear bumpstop replacement
  143. fuse question for 2nd gen
  144. Grugling Sound From Radiator
  145. Replacing my power antenna
  146. Top off switch on 4Runner
  147. SUPER difficult time changing starter. Tricks?
  148. Engine Miss, dealer gave up on it...
  149. 22RE Computer
  150. 2nd and 3rd gen extra cabs: common camper shells?
  151. Catalytic Conversion
  152. Wheel and tires
  153. mercedes diesel swap
  154. Wobble in Front end
  155. E-brake conversion question
  156. Mystery sheet metal
  157. stripped headbolt
  158. bottom shock mount help
  159. camber bolt for allignment??
  160. Gas Milage
  161. Locked 3VZ-E, waterpump?
  162. need some help??!!
  163. 22re LC Engineering Metal Timing Chain Guide Question
  164. 1992 yota 4wd 4cyl problems i need some advice
  165. remote back window
  166. Another transmission problem
  167. The Super Awesome Cupholder Mod! (89 4Rnr)
  168. SAS on my 90 , a few questions
  169. CV Shafts
  170. Will a Knock Sensor from an 87 22re PU work on a 90 22re PU
  171. Oil pressure drop
  172. seized piston on caliper
  173. How realistic is replacing the headgasket yourself
  174. Pic Request: 2nd Gen lower link
  175. Question about my dad's 94 toy's battery light and brake light staying on??
  176. Coolant system hoses.
  177. Exhaust manifold threads screwed... helicoil time
  178. My alternator wire burned completely off!
  179. rear view mirrors
  180. interior dissasembly question
  181. 300,000 miles and still going
  182. 92' Ovr Heats then Comes Dwn & is Cool
  183. Very rough engagement after manual tranny swap
  184. Tire/RIms Sizes
  185. Inexpensive eBay clutches
  186. smell of gas?
  187. SAS Front Axle?
  188. Aftermarket oil cooler for 3.0?
  189. Will a '94 throttle body fit and work with a 90 4runner?
  190. Is there such thing as a "quiet" hi-flow muffler?
  191. tranny won't shift when cold
  192. part #s for rear diff. and transfer case filler plugs
  193. differences in interiors of 2nd/3rd gen
  194. Intermittent Rear Antilock on 95 4Runner
  195. 22rtec coolant pipe needed
  196. HELP: Grinding noise out of front end.
  197. Rear Oil Seal Question
  198. Friction from Steering
  199. Charging System Question
  200. Needle Bearings
  201. Steering Gearbox Leak
  202. Transmission Whining in 3rd & 5th
  203. Negative Ground Locations
  204. steering fluid question
  205. Heater leak?
  206. A/C idler pulley...
  207. New Leafs. Any Ideas?
  208. Auto-Starters on MT
  209. Rear Window Switch By-Pass
  210. 2WD Transmission Swap
  211. Will a '94 body fit on a '88 frame?
  212. Auto trans problem
  213. 90 22re swap into 89 toyota truck questions
  214. compatable 3vze swap years?
  215. '94 3VZE... what is this?
  216. More CV problems
  217. Crank Bearings
  218. help with ARB install
  219. Stnd. CAb to extra cab?
  220. Swapping A 3.0 Yota Motor For A 4.0 Jeep Motor
  221. chip/module '91 4 Runner
  222. 3.0 Hard to start when cold
  223. Compatible vsv's for 3.4 conversion
  224. 91 4 runner auto
  225. ORANGE spark from coil
  226. Distributor needed/87 4-runner EFI
  227. Check Engine Light 2 questions
  228. Alternator belt and Electric Fan
  229. my oil light is coming on when revved and out of first gear is my pump bad?
  230. buying a winch and have a question
  231. 1991 Toyota Truck Factory Service Manuals
  232. 22RE timing chain installation?
  233. 91 4 runner
  234. 3.0 Missing/Bad Idle
  235. Transmission Solenoids
  236. Intermittent AC
  237. I thought it would be easier the 2nd time around with the timing chain
  238. Engine Temperature
  239. K&N Filter
  240. no start with electrical problem
  241. Balljoint Spacer Information
  242. Spindle Bushing Replacement
  243. My hubs won't lock
  244. measuring back spacing on wheels
  245. Rear Axle Bearings, Seals, Etc.
  246. 95 4runner coil spring spacer 1 1/4" or 2 1/2"
  247. 22re superchargers?
  248. Oil Pump
  249. Front diff. oil level check plug
  250. 3VZE Hard to Start...Clicking sound
