questions on installing an sr5 gauge cluster
Old Oct 29, 2006 | 03:20 PM
drpdmazda's Avatar
ok heres the situation, i got an sr5 gauge cluster and sending unit at the local junkyard, installed the sending unit and plugged it up, no problem. took out the old cluster cleaned up the new one and plugged it in, ok this seemed WAY too easy and was going to smooth. turn on the truck to check that the gauges work, heres where the problems start. the tach doesnt move at all the oil pressure gauge doesnt move at all, the temp gauge instantly goes to overheated and the fuel guage goes above full, and my tank is almost empty. can anyone help me trouble shoot the problems i am having, i did a search on here and didnt really come up with anything, i am assuming that the tach wire may have to be run directly into the dash which wont be a real big problem once i figure out which wire it is and where it goes, but any ideas on the other gauges? is this cluster pretty much shot?
any help would be appreciated
thanks
jason
Old Oct 29, 2006 | 03:24 PM
4runnerx3's Avatar
Are you mixing a v6 with a 4 cylinder?
Old Oct 29, 2006 | 03:28 PM
drpdmazda's Avatar
i asked myself the same question i was almost 100% positive it was a 22re 4cylinder but am starting to wonder. but figuring it is the 4 cyl i got it out of any ideas?
Old Oct 29, 2006 | 04:34 PM
dcg9381's Avatar
Yea.. that's really odd.. Different year perhaps?
Put the non-SR5 cluster back and everything is OK?
What year is your truck?
Old Oct 29, 2006 | 04:58 PM
drpdmazda's Avatar
my truck is an 89 4runner it came out of the same year just an sr5 i put my factory cluster back in and the factory sending unit and all works fine, the 4runner i took the cluster out of was definately a 4 cyl, i remember that it had the cylinder head off and only saw 4 pistons. so i am pretty confused right now
Old Oct 29, 2006 | 05:25 PM
dcg9381's Avatar
Me thinks:
1) Something about the plug wasn't in right.
2) Gauge set is dead. There is a procedure for checking the gauges in the FSM. It's pretty easy... I've never head of an 1989 that's not setup for a tach. The input is on the ignitor.
Old Oct 29, 2006 | 05:37 PM
drpdmazda's Avatar
Me thinks:
so should i try to plug it back in and wiggle the wires a little bit and see if that helps? and not to sound like a jackass but what is an fsm? factory service manual?
Old Oct 29, 2006 | 06:50 PM
86SR522REEFI's Avatar
you are correct good job using context clues.
Old Oct 30, 2006 | 02:27 AM
drpdmazda's Avatar
thanks, lol
is that the same as a haynes manual? or is there a different version/
thanks
Old Oct 30, 2006 | 02:49 AM
misterzee's Avatar
thanks, lol
thanks
FSM is from Toyota. A Haynes manual attempts to cover LOTS of areas in less space and just doesn't quite do the same job.
Actually, the guages didn't change at all over the later 80s, I spent a good bit of time troubleshooting a few months ago. Its a straighforward exchange...
To have so many issues with your system, there must have been something catastrophic done to that junkyard cluster. Those movements in there are pretty fragile...
Old Oct 30, 2006 | 05:14 AM
pokey's Avatar
Just did the swap in my 89 and the only issue should be with the oil sender needing changed out. My oil pressure gauge was bad and needed swapped so the troubleshooting stuff in the FSM helps a bunch. Not sure the year truck the sr5 gauge came from, but it didn't seem to matter anyway. Not sure how much time I'll have this evening, but I might be able to scan in a couple pages from the 89 FSM to help put you in the right direction. I'd also suggest watching for an FSM on ebay, I think i paid $60 for mine and it's worth every penny.
Old Oct 30, 2006 | 05:52 AM
trythis's Avatar
"it's pretty easy... I've never head of an 1989 that's not setup for a tach. The input is on the ignitor."
My 89 DLX did not come with a tach wire, just for the record.
Old Oct 30, 2006 | 07:07 AM
dcg9381's Avatar
Good to know... Never seen one like that.
Old Oct 30, 2006 | 03:07 PM
drpdmazda's Avatar
well i thank you all for the input, i guess its best to just assume that the cluster is shot, i hoped that would not be the case but seems it is looking that way
thanks again for those of you who gave me input, i will try and search out ways to test it before i give up all hope
jason
Old Oct 30, 2006 | 06:02 PM
misterzee's Avatar
jason
I bought one off ebay that had two bad guages, and i got another from a part-guy in town here, between the two, I made one good one. EZ to set your mileage to the proper place when you change as well!
Old Oct 31, 2006 | 05:04 AM
pokey's Avatar
jason
i didn't get a chance to scan any last night, as life sometimes gets in the way, but if you still need or want the troubleshooting stuff for the cluster, give me a pm. I have the FSM with me today and can scan it here at work and send it to you.
Old Oct 31, 2006 | 07:53 AM
stock87's Avatar
If you can take pics of the back of both clusters in enough detail, I can take a look and see if the dash connectors need the wires moved around. It's not common, but I have heard of it happening. Most are plug and play, although it's about 50/50 on the tach working. Usually you have to run a wire from the (-) side of the coil.
Old Oct 31, 2006 | 08:30 AM
RatLabGuy's Avatar
1 question.
Do both vehicles havet he same transmission (e.g., both autos or 5spds)?
The wiring pinout at the big connector is totally different for the 2 trannies. I.e., a cluster from a 5 spd will not plug right into an auto truck. Nothing wil lwork. I know this from experience.
You can make it work by removing the wires from the pins and putting them in the correct place.
Good luck.
Old Nov 4, 2006 | 12:56 PM
drpdmazda's Avatar
Originally Posted by RatLabGuy
1 question.
Good luck.
that must be the problem then, i went and got another cluster, went to put it in today and the exact same problems, identical, my truck is auto and both donor trucks were stick shift, does anyone know the pin config and how i would change it? i would greatly appreciate it
thanks again for all the help
Old Nov 14, 2006 | 09:08 AM
stock87's Avatar
Did that pinout I sent help? Ever get it working?
