broken rear leaf - replacement
Old Oct 28, 2006 | 06:31 AM
HAVOC's Avatar
Question broken rear leaf - replacement
I know someone with a broken pass. side main leaf.
specs: 1990 Toyota, 22RE, std. trans, 4X4, std. cab, shortbed.
Dealership wants $500 a piece for rear springs
I found a set on Downey's site: 2" lift for $200.00 a pair.
You have to reuse your load leafs, but that is no problem.
Why the big difference in price?
Anyone know of any other sources?
thanks...
Old Oct 28, 2006 | 08:25 AM
MtnToys's Avatar
Try some old man emu springs (OME). They are 2” lift, direct bolt on. The ride is far superior to stock and you can get them in heavy or medium duty depending on how much your buddy plans on hulling/towing. I would suggest you also get a pair of their shocks and greaseable spring shackle and bushings.
Old Oct 28, 2006 | 09:50 AM
4Crawler's Avatar
JC Whitney has stock height rear springs for about $150/set. Otherwise, try a junkyard for a used set: http://www.car-part.com/
Old Oct 28, 2006 | 11:03 AM
HAVOC's Avatar
I'm trying for somthing as close to stock as possible: I don't think he ever used it as a truck ('cept for going to the dump).
Thanks for the recommendations.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
