steering fluid question
Old Oct 23, 2006 | 06:20 AM
spudrunner's Avatar
Want to change out the power steering fluid in my 4 runners. Will Dexron III work can't find Dexron II?
Old Oct 23, 2006 | 07:15 AM
eric-the-red's Avatar
Yes, Dexron III is like 'improved' Dexron II, it's OK to use anywhere the II is specified. If you read the fine print on the bottle it'll probably say so somewhere.
Old Oct 23, 2006 | 07:19 AM
spudrunner's Avatar
Thanks, that's what I thought, just making sure it's not like brake fluid DOT 3,4,5 if you know what I mean.:bigclap:
Old Oct 23, 2006 | 07:59 PM
FredTJ's Avatar
Ah, but a higher rated brake fluid can always be used to replace a lower rated one.
You can run DOT 4 in a vehicle that requires DOT 3, etc...
Fred
Old Oct 24, 2006 | 05:40 AM
rezrunner92's Avatar
It's pretty much the same way with the Dexron rating, you can use one up but not down. The earlier Dexrons oxidize quicker. NEVER use a trans fluid labeled as "F" type in anything. Recently however the manufacturers have been going with their own transmission fluid "packages". I wouldn't use Volkswagen, Chrysler or Mercedes Trans Fluid in a power steering system but good old Dexron III is what I always use.
glowz825
Jan 25, 2022 09:28 AM
Up&Down
Aug 11, 2015 10:04 AM
gmonnie123
Jul 26, 2015 02:44 PM
voiddweller
Jul 15, 2015 03:56 PM
Poncho0206
Jul 10, 2015 06:21 PM
