Front diff. oil level check plug
Old Oct 20, 2006 | 02:49 PM
NRM's Avatar
NRM
so i've got some weird noise coming from my front drivetrain when i have my hubs locked, this happened after some off-roading this weekend and i also have a torn cv boot. i'm tryin to check the level of oil in the front diff. and i'm not exactly sure which bolt it is. it seems to be right on the front in plain view after you take the skid plate off but i just wanted to reaffirm that this is the right bolt to check the fluid. before i start taking stuff off. thanks in advance
Old Oct 20, 2006 | 03:15 PM
Glenn's Avatar
Is it on the side?
Old Oct 20, 2006 | 03:24 PM
NRM's Avatar
NRM
the one i'm talkin about is on the front, not the side. its the only bolt that seems reasonable to be the oil level check. my crappy haynes manual doesn't really say anything about the front diff.
Old Oct 20, 2006 | 03:38 PM
eric-the-red's Avatar
Sounds like the right one, should be a 22 or 23 mm.
Glenn's Avatar
The side/front means it's not on the bottom or the top. It sounds like you ahve the right one. Go ahead and try it if you have a 24mm socket.
Old Oct 20, 2006 | 03:40 PM
runethechamp's Avatar
I thought the front diff oil fill and check plugs used hex keys?
Old Oct 20, 2006 | 03:41 PM
NRM's Avatar
NRM
alright, gotchya. yeah its a 24mm. so thats gotta be the right one. thanks
Old Oct 20, 2006 | 03:42 PM
Glenn's Avatar
It's 24mm...I just checked my tools.
Old Oct 20, 2006 | 04:20 PM
all_terrain17's Avatar
Did you have trouble getting it out? That stock plug is paper thin for some reason...never got mine out to check the level.
Old Oct 21, 2006 | 09:17 AM
NRM's Avatar
NRM
well it seems to be a standard bolt. its def. on there pretty good so i'm gonna get the breaker bar out for it in just a little bit
Old Oct 21, 2006 | 02:00 PM
It's not supposed to be on super tight. Just make sure you're not tightening the bolt like I did when I got my directions confused laying under the truck to change my rear diff oil. Just see here:
https://www.yotatech.com/forums/f116/rear-differential-drain-bolt-82029/
Old Oct 21, 2006 | 06:54 PM
MMA_Alex's Avatar
lol yeah i used to always get confused while laying under my truck, crushed a perfectly good oil filter on my old explorer that way. You can try some pb-blaster, or wd-40 on that bolt too.
JF9243176
Oct 8, 2017 04:21 AM
JF9243176
Jun 24, 2015 04:53 AM
