What would cause a timing chain to break?
Old Oct 28, 2006 | 07:51 AM
Evrgrnmtnman's Avatar
Okay, new timing chain installed because old one broke. Truck still won"t start or get a spark? Could it be bent valves that broke the other chain? Reason didn't pull head, engine has 190k, two years ago I put a re-conditioned head on it, so worst case scenerio I buy another engine instead of keep pumping money in this one.........????????????
88 Pickup,22RE,5spd.
Old Oct 28, 2006 | 08:30 AM
ovrrdrive's Avatar
if the other one broke when the engine was running (duh like it would break when the engine was stopped) you probably bent the intake valves...
As for why it would break, all I could guess is that a piece of the guide might have gone through the sprocket like it did on mine or it was just its time.
Try doing a compression test.
Old Oct 28, 2006 | 09:54 AM
Aetsen's Avatar
You probably have some bent valves, I almost didn`t pull the head when my chain broke but I decided to do the whole bit and check it out.
But I`m not sure why you wouldn`t have any spark.
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
skoti89
Jul 6, 2015 07:45 PM
