My alternator wire burned completely off!
Old Oct 24, 2006 | 10:46 AM
OSIRIS's Avatar
the wire on the alternator that goes to the battery is burned off at the connection with the alternator?
Time for a new alternator?
Time for the 'big 3 or 4' wire upgrade?
All the above?
Old Oct 24, 2006 | 10:58 AM
mastacox's Avatar
Sounds like a lot of current was getting pulled... were you running a lot of accessories, or do you have a short somewhere? Big 3 Upgrade could be an option, but you should figure out what CAUSED this first...
Old Oct 24, 2006 | 11:26 AM
mt_goat's Avatar
Burned off huh, got any pics of that?
Old Oct 24, 2006 | 12:30 PM
AlaskaToy's Avatar
probably was a poor connection, got a little corrosion, resistance of connection got higher, resulting in more heat, resulting in faster corrosion, heat, corrosion, heat, corrosion, until it was all over. Probably worst right after startup when alt output was high to recharge the batt.
Old Oct 24, 2006 | 12:36 PM
OSIRIS's Avatar
I agree, I need to find the source of the problem and fix it. I had the engine swapped out and perhaps this is an effect of something they missed. Could this happen if the engine to chassis ground was not connected or broken since then. I do not have any accessories yet. I have a stereo to install, but I was waiting until I was able to solve this problem first. The batt light came on and then went off sparatically over the past couple of weeks and I looked at the wires and there was nothing to see out of the ordinary. Today the batt light did not turn off but at least I made it to work! Getting home - another story.
Ok so, for the wire to fry itself at the base of the alternator that is a sign of current being pulled out of the alternator? I do not think it was the regulator frying and causing too much voltage to flow because I would have seen that on the meter in the car and did not, so I think you are on the right track that it was current. Having a bad ground would cause more current to be pulled?
She runs fine, no sputter with this problem.
Thanks for your help.
Old Oct 24, 2006 | 12:47 PM
AlaskaToy's Avatar
poor ground=less current.
batt light was coming on because the connect was so wasted the batt was not getting sufficient charge from the alt anymore. Unless you have a batt with internal plates shorted, there was no over current condition. the stock allt can oly put out 65 amps anyway.
Old Oct 24, 2006 | 12:48 PM
OSIRIS's Avatar
Then how would it get so hot to burn off that connection like that?
Old Oct 24, 2006 | 01:10 PM
AlaskaToy's Avatar
because any current across a resistance make s heat. If you had a poor connection, there's some finite resistance there. That resistive connection probably got hot. Heat increases chemical processes, including corrosion. You can see the "vicious cycle" emerging here. FWIW even just 10 amps will generate some serious heat across even a relatively small resistance.
Old Oct 27, 2006 | 05:40 PM
84sr5yoty's Avatar
Usually poor connections cause a certain degree of arcing, depending on the amperage and voltage of the circuit. The arching usually melts the insulation (and sometimes the wire) and chars the connection.
Old Apr 16, 2009 | 05:47 AM
NassauBob's Avatar
Not the alt-battery wire, ....
All the above?
On my truck, a '94 4X4 Auto Trans, the wire from the alternator to ground (terminates on alternator mounting frame above) burned this morning, during a failing attempt to start. It would turn over very sluggishly, then not. I happened to peek out the front, and I saw smoke coming out of the driver side front of the hood. Of course I was suspicious, knowing that the battery is on the other side, so I got out and looked. The wire that is fastened to the adjustable mount for the alternator and goes down into the loom directly below the steering knuckle boot was fried.
Is this the alternator ground wire? I assumed it was so, because what else would be grounded there? And if it is, should I assume that the battery is fine, and just replace the wire in question?
Thanks,
Shane
Old Apr 16, 2009 | 05:56 AM
mt_goat's Avatar
Thanks,
Shane
A pic might help. Was the connection loose maybe?
redneck17
Oct 29, 2015 09:09 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
smiley52
Jul 11, 2015 05:16 AM
colinmil
Jul 6, 2015 04:03 PM
