'94 3VZE... what is this?
Old Oct 22, 2006 | 12:58 PM
rdharper's Avatar
What is this?
What does it do?
What service is required (I think the note on it refers to the Air Cleaner to the right).
Couldn't find it in my Chilton manual. It may be called a Breather Filter, but can't find any references to it using search, or google search.
[IMG][/IMG]
Thanks
Old Oct 22, 2006 | 01:03 PM
Elton's Avatar
just for pepole that are stupid and dont know when to replace the filter
Old Oct 22, 2006 | 01:09 PM
rdharper's Avatar
The question is with respect to that box, which is not the air filter, but attached to the air filter. Maybe an input from the PCV/crankcase?
Old Oct 22, 2006 | 01:48 PM
Astralplane's Avatar
It's the "Resonator"
Check out this link:
http://www.the-roo.com/4runner/Engin...s/pulsedse.pdf
Old Oct 22, 2006 | 01:59 PM
marko3xl3's Avatar
Or simply, an intake silencer. It just quiets down the intake and is only a hollow box with no maintenance requirements. Take it off and you gain some throttle response and a whole lot of WROOM! There are write-ups on it everywhere, it's called the ISR (Instake Silencer Removal).
Old Oct 22, 2006 | 02:23 PM
rdharper's Avatar
Thanks Astraplane and marko, that does it, I get it.
Don't know why I haven't got around to getting the FSM... will order it now.
Old Oct 22, 2006 | 08:10 PM
Tigerstripe40's Avatar
that piece is the air chamber for the PAIR Reed valve.
The Intake Silencer sits behind and below that and has nothing to do with that piece.
Old Oct 23, 2006 | 07:05 PM
Bumpin' Yota's Avatar
100% correct!!!
That air chamber makes the noises from the Reed Valve go away! Believe me without that chamber you WILL hear the reed valve over everything else.
Old Oct 24, 2006 | 07:52 AM
AlaskaToy's Avatar
Originally Posted by Bumpin' Yota
...without that chamber you WILL hear the reed valve over everything else.
UNDERSTATEMENT! I will be putting mine back in. Too annoying without.
Old Oct 24, 2006 | 02:46 PM
100% correct!!!
I put that stuff together on my motor rebuild earlier that day.
Old Oct 24, 2006 | 04:00 PM
rdharper's Avatar
100% correct!!!
Right... thanks to the responses here, it is clear that this chamber is a resonance chamber (like a series capacitor in an electriical circuit) which bucks the reed valve at the right frequency).
Thank you all again, for bringing clarity to the original question.
glennherbers
7
Mar 17, 2016 03:42 PM
chukarhunt
Apr 21, 2014 07:42 PM
Popcan
Oct 21, 2013 12:28 AM
jwpalmer82
Jan 18, 2013 03:10 PM
noble
Jan 16, 2011 07:00 PM
