2nd Gen Runner in the Cold
Old Oct 26, 2006 | 07:48 PM
AUYota's Avatar
On cold mornings when I crank up my runner it cranks up to a high idle- about 2.5k. Is this normal? If not fixable? if so- easy or hard to fix? What do i do? should I worry?
Old Oct 26, 2006 | 07:53 PM
91_4x4runner's Avatar
On a cold morning here in texas (~50 degrees), my engine idles at 1.5k until it warms up where it idles at about 600rpms (2-3 minutes of driving later).
Old Oct 26, 2006 | 07:59 PM
AUYota's Avatar
Mine is at 2k+ in the cold and yes it idles down as the engine warms up. It's kinda creepy though. I have a manual tranny and I can idle the Runner across the parking lot like i got a an automagic. But that can't be good I know...
Old Oct 26, 2006 | 08:03 PM
I've got a manual trans. as well and mine idles accross a parking lot at 900 rpms (which is weird how my engine fluctuates the idle). I'm not sure if it's possible to adjust the cold-start idle, but 2k is definitely high.
Old Oct 26, 2006 | 08:08 PM
AUYota's Avatar
new rebuilt too... It's got a bad knock sensor so I wonder if that has something to do with it as that makes the computer run the motor a little more...
Old Oct 26, 2006 | 09:23 PM
Jay1's Avatar
Is their a way to ajust the cold ideal on a 86 yota pickup with EFI?
Old Oct 27, 2006 | 03:04 AM
AH64ID's Avatar
Thats about normal for a cold start morning. Not really a way to regulate the cold start injector, on or off.
Old Oct 27, 2006 | 07:23 AM
all_terrain17's Avatar
I asked this question one time...and yes, cold idle can be adjusted...
There's an air valve beneath the throttle body with small coolant lines running to it. The air valve is responsible for the high cold idle - it lowers the idle only when warm.
https://www.yotatech.com/forums/show...high+cold+idle
https://www.yotatech.com/forums/f116/low-idle-startup-73563/
Couldn't adjust mine, turns out somebody lock-tite the screws which hold the air valve to the throttle body.
Old Oct 29, 2006 | 04:32 PM
AUYota's Avatar
Any idea where this screw is on the V6?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
