determine this cooling system hose
Old Nov 1, 2006 | 06:28 PM
freshman's Avatar
it is connected close to the oil filter of my 90 4runner auto 3.0 v6. We cant find the place to connect it! [IMG][/IMG]
Old Nov 1, 2006 | 06:30 PM
freshman's Avatar
we are finishing our water pump replacement and run to this problem of where to connect this hose....
Old Nov 1, 2006 | 06:39 PM
DudeBud's Avatar
does it not go to the water pump.
Old Nov 1, 2006 | 06:42 PM
HAVOC's Avatar
looks like the bypass hose for the water pump
Old Nov 1, 2006 | 06:57 PM
callmej75's Avatar
Looks like your oil cooler hose. Look right below the thermostat housing. Look in this pic I took when i had my motor out...notice the hose right under the thermostat housing.
Old Nov 2, 2006 | 07:57 AM
callmej75's Avatar
Originally Posted by freshman
i cant locate the adator for my oil cooler hose basing from the pic above... how is this hose attached? Close up pic will be great help!
I edited the pic...hope that helps more
Old Nov 2, 2006 | 11:26 AM
freshman's Avatar
last hope. where on this pic the hose from the heater core attaches?
[IMG][/IMG]
Old Nov 2, 2006 | 11:30 AM
freshman's Avatar
one more.... btw, thanks for the pic courtesy of yotatech archive. Yotatech rocks![/IMG]
Old Nov 2, 2006 | 12:16 PM
callmej75's Avatar
IIRC there is an extra hose line that comes off of the water pump next to the thermostat housing....there are 2 types of water pumps that you can buy for the 3.0. One with or without the cooler line. This hose you are referring to IS NOT the heater core. I rebuilt this engine before and I know. In this pic that you are posting from the archives, they have the oil cooler blocked off it looks like. Your mechanic might have bought the water pump that does not have the extra oil cooler line coming off from it. Please someone correct me if I am wrong.
Old Nov 2, 2006 | 12:25 PM
callmej75's Avatar
Ok...check here http://personal.utulsa.edu/~nathan-b...09waterpum.pdf
Notice on the thermostat housing there is a small hardline coming off of it....theres where that line attaches to. Call your local auto parts store and ask them for the price of a water pump and ask them if they have 2 different water pumps listed...one with and without the oil cooler line coming off from it. If they say yes....then call your trusty mechanic and tell him he got the wrong water pump on it and change it out WITH the oil cooler line that comes off the thermostat housing.
Old Nov 2, 2006 | 01:01 PM
freshman's Avatar
problem solved! my trustee mechanic installed the one without heater outlet. Now, can i live with it or need to change it... $$$$$$
what will happen living this water pump there and plugging the hose?
Old Nov 2, 2006 | 01:08 PM
callmej75's Avatar
Haha...its not a heater outlet man....its the oil cooler line. It cools the oil while your engine is running. If it were me...I would take it to the mechanic, and have him replace it FREE of charge since he obviously doesn't know what the hell he is doing. I guess he lives by that philosophy that its meant to have parts left over and not accounted for....
Take a look at the diagram on that site I sent you....it says No. 2 Oil cooler line.
the1998sr5
15
Jul 14, 2020 08:35 PM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
kyletbert
Jul 17, 2015 11:39 AM
Avenged
Jul 9, 2015 07:55 AM
