22RE Distributor Help
Old Oct 30, 2006 | 05:35 PM
4RunnerLVR86's Avatar
Question 22RE Distributor Help
I bought anouther 22RE for my 86 4Runner and the new engine has a vacum thing on the distributor and the orginal one dosen't. What does the vacum thing for?
Old Oct 30, 2006 | 05:54 PM
84sr5yoty's Avatar
It's the vacuum advance. Are you sure it's a 22re? Only 83 (Celica only) and 84 (Celica and 2WD SR5 pickups only) 22re's used a vacuum advance can. You may have a 22r motor.
Old Oct 30, 2006 | 07:29 PM
I know for sure its a 22RE out of a 87 4Runner. What was teh vacum advanced used for?
Old Oct 30, 2006 | 07:36 PM
dcg9381's Avatar
It's used to advance the timing at idle. It's a mechanical system. The 22RE EFI doesn't use it. There is a chance that it will "work" - it certainly will drop in to the head. It's also a 2 wire setup that may plug in.
It's *not* the right distributor the VAST EFI ignition system. If it runs, my guess is that the ignitor is defaulting to limp home timing...
montanatruck
Feb 26, 2017 07:07 AM
nonstop
7
Aug 11, 2015 09:26 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
