- Custom Truck Bed Storage?
- 87 turbo 4runner auto trans and transfer swap question
- *** Quick question about downey leafs, working in progress!!***
- its moaning!
- 6" lift driveline vibes?
- Blue wire w/ a white line, stock stereo.
- My Poor Truck
- Tiger Engines vs. GotEngines.com
- rattle can
- crank no start
- Cut Quarter
- Newbie - Need help with Multiple Coolant Leaks - Fix or Sell
- Up and down idle
- Heater problems
- new rubber!!!!
- 3.0 gears
- 2.4 vs 3.0
- Just a yes or no will do.
- Lift Shocks
- 160 or 180 thermostat?
- 87 4 runner
- h2o
- 87 Buildup Thread! Engine REBUILD and more to come soon!
- low oil pressure - what do you think
- what could cause this?
- Toyota Quality?
- Auto tranny ?
- I need more power from my 3.slow v6
- drilling holes in headlights
- 90 4runner need help....
- 1991 SR5 Toyota X-Cab 4x4
- Rear seat shoulder seatbelts
- CV boot leaking at clamp
- Need Pics for Help
- Retrofitting ABS
- How to shorten the top?
- looking for winch bumper, opinions?
- Antenna cable removel from cd player
- Differential Sensor?
- 3.0 engine parts
- Manual locking hub noise
- 89 4runner overheating
- Ever block (partially) your radiator in the cold?
- Fuel Pump Question 22re
- What idler arm is this?
- Beck Arnley tie rod ends
- Locker opitions-opinions?
- 86 4runner Header Gasket?
- ECU Convertion?
- idle problem after warm 22re code 5
- Replace entire EGR or just the diaphragm?
- brakes HELP!!!
- Building in stages
- Flowmaster 40 vs Flowmaster 50
- cat converter gasket
- who else besides me can actually use 5th gear on a 22re??
- 87 Truck 22r Chugs in 5th gear over 50mph
- OME 901 ?'s
- ineed a set of matching 4 fender flares HELP
- '94 Pickup Tailshaft oil seal replacement?
- question about headlight buzzer
- The Nasty Thread
- mirror install
- Engine swap electrical question??
- PIAA vs. KC vs. Hella vs. HID
- 22R No Spark
- Top Tranny Bolts
- New winch =)
- Speedometer problem--help please!
- 1988 Buildup w/ Pics!! SAS'd, Bobbed and more to come!
- Two Knock Sensor Part Numbers for a 91?
- Rattling and other noises
- Truck Squeals On Launch
- Reinforcing center link
- Toyota 1986-1989 1/2 Truck vs. 4runner
- q on using an aux tranny cooler
- 95 Pickup 4-wheel drive noise
- I kill my engine
- Tough roll up windows
- Starter trigger wire
- Axle retaining clip missing
- battery/intake swap
- Radio antenna annoyance
- 22r.. It turns and turns and turns and turns
- negative camber stumped?
- Low Idle help
- Hub Sizes- Can you identify?
- Are these door panels an option or something?
- 22R Alternator "Lamp-On Voltage Failed"
- where can i find this camper shell???
- 4Runner Tailgate Window
- 22re idle and rev issues
- OK another head gasket question
- 87 yota pickup question
- Anyone know the dimensions on the idler arm bushings on 93 4wd?
- 86 Yota W/ 22R, Very slow cranking starter
- 22re cam
- Where do I go from here? Need expert advice on gearing, locker, armor.
- 92 v6 problems
- Need help, lift kit ideas...
- clutch pedal HITS FLOOR....news at 11
- 80 series springs in a 4 runner
- Selling 89 toyota 4runner!
- TDC / Distributor Replacement / Starting Guide
- 3.0 V6 Coolant in oil?
- Where does the air this hose go?
- 33 12.5 15
- Dual battery set up
- Anyone has a rear relocated shocks patern / \
- just blew my engine 93 4runner 3.o HELP???
- help... engine wont start
- bleeding brakes...HELP!!!
- FJ80 diffs for SAS?
- spark plug issues T_T
- Anyone know where to get fender trim?
- 1st gen 4rnr with sleeper...
- 89 4runner dilemma
- What gear do you have?
- my 3.0 to 3.4 upgrade
- easy TDC
- Header help
- 2nd Gen 4runner Rear seat
- Help please
- found these sweet 2nd gen headlights
- Good buy? Locker
- starter woes
- Question concerning Dr Zhivago's ECT Mod
- 3.0 lIFTERS
- code 25
- 2WD 1st Gen 4Runners?
- Ball Joint
- Coolant Leak
- Stiffening 2WD Suspension
- 93 4runner transfer binds...
- Subtle but very nice ambient light
- weber tuning= FUMES
- Craigslist Find
- 4crawler leviling kit on 94 4runner
- My 92 4Runner thread
- Redundant thread :) Power Steering
- no ignition spark
- 4runner Accessories
- 33x10.5's w/BJ spacer and stock wheels???
- 32x11.50r15
- Ox Sensor testing.
- clarify: flushing heater core
- how to install a distributor?
- snapped e-brake... again
- Me and my Runner
- idle mixture srew
- truck is stalling at temp...
- what do i need connected to start my engine?
- spark plug question
- The ol' oil & coolant prob
- Tranny pilot bearing on the way out?
- Rancho Upper Control Arms
- 2nd Gen 4Runner Rear Wiper Blade?
- 1st/2nd gen bumper mounts...help!!!! major problem i need to solve
- Mech in NH?
- bottom end rebuild. help
- Need some help
- What size lift should i get
- Spark Knock (preignition) with 93 octane and 0 degrees timing
- Seat Swap
- Finding body parts that are in good cond.
- hard start
- Bad gas mileage/low power/lean?
- Running Rich and lack of power after HG replacement
- start up noise
- Replaced heater core - STILL NO HEAT! HULK SMASH!
- '88 4runner water hose problem (22re)
- 2nd gen 4runner 3in body lift
- which transmission do I have?
- parts that are cheaper from the dealer
- thermostat location.
- Front Drive Shaft Removal Issues
- Looky what I finally got!
- toyota pickup ball joints and wheel bearings
- 22re no power, loosing coolant New HG
- need an new antenna
- Look what I got, Look what I got!
- More power on full tank??
- Okay, stupidest thing ever , I did it...
- 3VZE Engine Coolant Drain Bolt size ?
- My holy 3.0 I guess this changes everything
- Where and What to Buy?
- hi lift jack on wheel well
- sticky throttle
- '96 obdll codes
- Possible New Runner
- What is the AMF?
- Weird squeal at startup..
- major front diff issue
- Total Chaos Long Travel Install
- I think I bought a lemon
- Heater stopped blowing hot air
- transmission temp gauge sender palcement?
- 22re engine ground
- removable mud flaps
- Selling price for my 92 pickup?
- My 22re does not have the famous chatery idle...... :(
- could i get some pics of a 32/36
- Found my rear end problem :D
- Headers for 3.0 whats my options
- Check this out.
- 87 22R idle problems
- hard start
- New doa 22re motor
- Sky crossmember/skid plate
- bored pictures
- 22re coolant loss
- Out of Ideas!!
- truck blowing coolant
- Should I go 93-95, or 96-98 4 Runner, dumb it down for me.
- What JDM parts were produced/available that U.S. didn't get?
- drain t-case for seal replacement?
- Will this work?
- Cut a Rust free Vehicle?
- New Locker Install!
- Stock 87 4runner
- Whats my truck worth?
- Torsion bar question...
- Price on T100 Rolled!
- Starter ID for 94 SR5?
- cutting the manifold
- Performance
- Urgent! Carb Help Needed Please!
- idler pully tensioner broke!
- New Parts, Your Input
- Winch with no power?
- another buckshot question.
- Show me all ur pictures of your SaS'd 89-95 4runners
- Replacing the oxygen sensor?
- V6 vs. 4 Cyl.
- FJ Bilsteins on a '90 4x4
- ProComp Bracket Lift
- Orange Tail Light Sybdrome
- 4wd oil pan onto 2wd motor? it won't fit!
- Brand New 22r Block?
- time to change the fluids
- relay wire kit for H4 conversion off ebay
- Need picture of your alignment cam bolts
- Good Exhaust Shops Around Portland OR
- here we go again
- Fuse box and wiring diagrams needed
- a little update..
- Where to find a stock inclinometer for a 92 4Runner
- most miles in a single trip in my toyota sense rebiuld went well
- Looking at 92-95 4Runner, advice please...
- Wire? 93' 3.0
