3.0 engine parts
Old Jan 15, 2009 | 08:35 AM
FUSOTECH's Avatar
3.0 engine parts
Would like to hear form you guys about the quality of parts from engnblder.
The prices look great. I see a lot of post from people using these parts. I am
going to do a complete rebuild instead of just head gaskets. I just want the
straight - up skinny on engnblder parts and how these parts compare
to other major brands (Fel-pro,Sealed Power,JE,ect...)
Old Jan 15, 2009 | 11:02 PM
thook's Avatar
Well, engnbldr supplies Rock, Top Line, Hastings, and King parts. All quality. I've used them in both of my Toyotas, to varying degrees, with great results.
Old Jan 16, 2009 | 04:40 PM
FUSOTECH's Avatar
C'mon guys,out of all the members on YOTATECH only one has used engnbldr parts?
Old Jan 16, 2009 | 09:24 PM
idanity's Avatar
i use oem...
i dont even know what engbllgor is ..(forry)
Old Jan 18, 2009 | 07:18 PM
Green93's Avatar
I used engnbldr parts in my rebuild. I haven't had a problem yet. He has the best customer support you'll see as well.
Old Jan 18, 2009 | 09:44 PM
Jay351's Avatar
SEARCH!! There is literally hundreds of pages of info on how great engnbldr is
Old Jan 19, 2009 | 09:49 AM
FUSOTECH's Avatar
Thanks for the info.
Old Jan 19, 2009 | 03:46 PM
merace19's Avatar
I got a timing belt for a 3.0 from ( ) . Only issue was it didnt have the white marks to line everything back up.
Old Jan 20, 2009 | 09:01 AM
runethechamp's Avatar
I went all OEM. The service is the best ever at engnbldr, but my machine shop guy did not like the parts from there. I don't know enough about engines to form my own opinion, but I trusted my machine shop when they recommended I get something better. For me the extra money was worth the piece of mind of knowing I had parts from Toyota.
Old Jan 20, 2009 | 09:31 AM
nv4runner's Avatar
I ordered the Full Gasket Set from engnbldr to replace my head gaskets and all the associated gaskets and seals. Excellent quality and I probably got more gaskets and seals than if I had bought it from Toyota, and it cost less!
Under the Advanced Search I typed in engnbldr and searched titles only and here are four of the top five threads:
head gasket.....engnbldr?
engnbldr
Engnbldr (in Customer Feedback for Vendors)
ENGNBLDR Rocks!
Old Jan 20, 2009 | 02:26 PM
devinwwu's Avatar
i did the full engine rebuild kit for my 3.0 as well. everything has been great! THe one thing i wish it had that it doesn't is a new water passage/timing belt tensioner.
the marks on the timing belt are unnecesary as long as you make sure the timing marks on the cams and crank line up correctly after 2 rotations after install
i ended up not using some of the paper type gaskets because the FSM said to just use the toyota sealant (FIPG) for most pieces.
Putting the rebuilt 3.0 in tonight if everything goes well and i'll let you know how it all works
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
OffroadRalph
Jul 2, 2015 07:28 PM
ZONAYODA
Jun 30, 2015 05:36 PM
nyk08trx
Jun 18, 2015 09:01 PM
yamaha73
Jun 18, 2015 06:19 PM
