87 22R idle problems
Old Jan 9, 2009 | 04:34 PM
57bronco's Avatar
I bought an 87 pickup 22R, 2bbl carb, 4X4, 5spd, 210k mi., a couple of months ago.
I have an idle problem. It cranks up just fine, but when it worms up to operating temp it idles up to about 2100rpm’s. All vacuum hoses seem ok, I disconnected the fast idle, no luck.
I drove it over 300mi in one stretch, never did idle down.
Old Jan 9, 2009 | 05:00 PM
ptool2000's Avatar
I've been having a similar problem, but I still yet to find the solution.
Old Jan 9, 2009 | 05:52 PM
abecedarian's Avatar
Improper timing?
Otherwise, if the carburetor is operating properly, and the fast idle cam and throttle cable aren't hanging, little more than a vacuum leak will cause the problem.
Old Jan 9, 2009 | 07:30 PM
57bronco's Avatar
Timing is correct, all vacuum lines ok. I am going to check the intake and carb for cracks or a loose throttle shaft tomorrow.
I should have already checked the carb, but it slipped my mind. I may need to make some bushings for the throttle plate.
Originally Posted by abecedarian
Improper timing?
Old Jan 9, 2009 | 07:35 PM
Kiroshu's Avatar
Adj Idle? Throttle sticking? Wonder if the 22r's have coolat temp senosrs that might be it.
Old Jan 9, 2009 | 07:42 PM
22r's have coolant temp sensor. However, since the carb determines the fuel mixture, the sensor has more effect over timing (vacuum advance / retard) than the fuel mix... yet affecting timing affects the mixture. hmm....
Old Jan 9, 2009 | 07:48 PM
57bronco's Avatar
I can take the idle screw out and remove the throttle cable, no affect. If I force the throttle by hand it will idle down, but when I stop it returns to about 2100 rpm's. When I start the engine cold it idles at about 1000 rpm.
Old Jan 9, 2009 | 08:06 PM
Kiroshu's Avatar
I belive he has a bad sensor if i were just to start changin parts thats what i would go for first. Maybe you got soemthin defective in your throttle body.... Hmm...
Old Jan 9, 2009 | 09:25 PM
so if you force the throttle closed, it'll idle fine.
seems to me that something is preventing the throttle from closing... based on what you just said.
Old Jan 10, 2009 | 02:20 AM
57bronco's Avatar
That's what has me befoozled. Nothing on the outside of the carb is causing this, as far as I can see. oProbably a vacuum leak?
Old Jan 10, 2009 | 07:53 AM
Kiroshu's Avatar
Has the throttle body been changed before. Someone might have made a boo boo
Old Jan 10, 2009 | 01:56 PM
57bronco's Avatar
Thanks to all
I checked for leaks with carb cleaner, no luck. I'll get a kit and rebuild the carb next weekend. I might just pick up a Weber. Thanks for all the input so far.
Old Jan 10, 2009 | 02:11 PM
parkkicks's Avatar
hey sorry for the hijack but i just put in my weber 32/36 and am having the same problem. the throttle arm linkage deal wont close all the way. the idle screw dosent even touch the linkage? anyone know how to fix this?
oh and throttle bodies are fuel injected engine components.
Old Sep 22, 2021 | 03:39 PM
rob8steak's Avatar
Did you figure it out?
Looking through all the threads.....this is the problem I am having now. Any luck finding a solution?
I remove the idle screw and put it back in....this allows me to adjust the idle properly. I turn on my AC and it draws down the idle. Then when I turn it off the AC the idle shoots back up and can't be adjusted by the idle screw. I'm thinking there is a problem with the throttle body.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
