Axle retaining clip missing
Old Jan 13, 2009 | 03:14 PM
fdeeznutz's Avatar
When I took my front end apart recently I noticed that the drivers side axle was missing the retaining clip that holds everything together. I used to have some clunking noises coming from the front end when I turned. I wonder if that has anything to do with it.
Also when I had the truck in 4-hi (only did it once) and got up to around 40mph I got a real nasty clunk/grinding noise. Do you think this was related to the clip being missing? I already ordered and picked up the missing clip from the dealership, just seeing if anyone had any thoughts on this. Thanks!
Old Jan 17, 2009 | 11:30 AM
fdeeznutz's Avatar
After installing the clip no more clunking noises around corners.
Haven't tried it out in 4wd yet.
Old Jan 17, 2009 | 11:32 AM
abecedarian's Avatar
did you forget to install the axle retaining clip retaining clip?
anyways... yay!
Old Jan 18, 2009 | 12:11 AM
DeathCougar's Avatar
to answer your original question, yes not having that clip in there will cause the describe symptoms. reason being, the axle will back out the spindle at the most inopportune moments.
Old Jan 18, 2009 | 05:21 AM
874runnersr5's Avatar
good thing you caught it!
i hate when your working on your rig and you dont find something thats suppose to be there. damn previous owners.
Old Jan 18, 2009 | 05:27 AM
Beaniam's Avatar
make sure it's not worn out either or you'll end up with something like
http://beaniam.com/cars/truck/stripped2.JPG
Sleaker
Aug 26, 2020 06:03 AM
coffey50
Jul 28, 2015 10:55 AM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
colasurdo
Jul 16, 2015 11:32 AM
