FJ Bilsteins on a '90 4x4
Old Jan 8, 2009 | 01:26 PM
pathfinder's Avatar
Just wondering if rear FJ bilsteins will fit my '90 4x4 pick up? And since I'm posting, I'm going to install toytec's 2" lift on my truck, curious if I can get away with the stock shocks for the time being if I'm not off roading much?
Old Jan 8, 2009 | 01:57 PM
space-junk's Avatar
do some research to find out what the shock length is on the FJ shocks...
im guessing that they should work since there is a guy who used FJ springs on his runner...
Old Jan 9, 2009 | 05:14 PM
Matt16's Avatar
It should, they both have a pin/stud at the top and a hoop at the bottom. They probably use the same size bushing at the bottom as well. The FJ shock is slightly longer than the 4Runner shock, so make sure your rear bumpstops are intact (bottoming out ruins the shcok..)
let us know how it goes.
Read this, https://www.yotatech.com/forums/f116...thread-141193/ then find out how long the FJ shocks are. Don't use shocks that are too long as if you bottom out a shock, you will destroy it.
mussy01
Dec 13, 2016 08:20 PM
defrag4
Jul 31, 2015 10:50 AM
mr_manny
Jul 31, 2015 10:39 AM
PopsDad1
Jul 30, 2015 02:21 PM
4Runnin2000
Jul 29, 2015 06:09 PM
