Heater stopped blowing hot air
Old Jan 9, 2009 | 08:15 PM
88wildrunner's Avatar
one day a week or two ago my heater just stopped blowing hot air, it will only blow out cold air. i cant seem to find the reason why it dosent blow hot air anymore, does anyone have any idea why it would stop or what i should check.
Old Jan 9, 2009 | 08:29 PM
toyota4x4907's Avatar
Clogged heater core or lines to the heater core. Heater core may have just gone bad. Low on coolant?
Old Jan 9, 2009 | 10:22 PM
DeathCougar's Avatar
Check your heater valve as well for operation. If it wont move or open, you won't have any hot air.
Old Jan 10, 2009 | 12:49 AM
annoyingrob's Avatar
I 2nd the heater valve. Is it vacuum operated on these motors? I can't remember. If so, check the vacuum line running to it. Without a good vacuum source, it won't pull open.
Old Jan 10, 2009 | 01:45 AM
idanity's Avatar
x3 on the valve..especially if it just stopped, and was previousely working fine.
in the engine bay, on the firewall, right on top(ish), is 2 hoses, and one w/a brass fitting that slides...try manually moving it in the opposite direction it is in now, and go for a drive..
Old Jan 10, 2009 | 07:37 AM
It is not vacuum operated, its cable operated. You can operate from inside while a buddy watches the lever action, or just disconnect the cable at the valve and operate it yourself.
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
jjrbus
Jul 19, 2015 02:06 PM
sojourner567
Jul 16, 2015 08:52 PM
the1998sr5
Jul 16, 2015 06:20 AM
