sticky throttle
Old Jan 10, 2009 | 09:07 AM
parkkicks's Avatar
sticky throttle
i just installed my weber 32/36. im just having a problem with the throttle mechanism. it doesent sit on the idler screw and is very sticky and i cant adjust the idle.
any ideas on how to loosen it up? i already tried a silicone spray.
also do you think i need a tighter spring?
im on the home stretch so all help is GREATLY appreciated
Parker
Old Jan 10, 2009 | 05:38 PM
Jay351's Avatar
Clean out all the gunk inside the throttle body Clean all around the butterfly.
Old Jan 10, 2009 | 06:22 PM
Matt16's Avatar
Jay, I think its a brand new carb.
WD40 may actually work for this, it does a decent job on lubing parts without gumming them up. After spraying on, I'd work the throttle back and forth for a couple minutes or until it moves freely.
Old Jan 10, 2009 | 07:31 PM
parkkicks's Avatar
alright guys thanks. i will try really lubing it well tomorrow. but it seems like the spring just isnt strong enough to return the throttle all the way. is that possible and if so where can i get a stronger spring?
thanks
Parker
Old Jan 10, 2009 | 07:40 PM
Matt16's Avatar
I have no idea what the spring looks like on a Weber carb, why don't you take a picture of the spring. If its like the only on the 22RE, its probably proprietary.
Does the butterfly close when the throttle cable is not attached? If so, go buy some "chains lube" (for motor cycles), disconnect the cable at the carb, and try to spray the cable lube down the sheath.
Old Jan 10, 2009 | 08:25 PM
Jay351's Avatar
Sorry, my mistake. I totally mis-read that.
Spray some lube in the pivot points and chain lube in the cable.
Try working it back and forth by hand, perhaps its just sticky because its new?
Old Jan 10, 2009 | 10:01 PM
parkkicks's Avatar
well heres the best way i can describe it. looking from the front of the truck the bracket is pointing at 11 o clock. if you move it between there and about 1 o clock it will not return. if you move it past 1 o clock it will return to 1 o clock.
i will give it a good lubing tomorrow.
thanks for the advice i will keep you posted
Parker
Old Jan 11, 2009 | 02:15 PM
parkkicks's Avatar
alright got it fixed sprayed the whole assembly down with silicone spray. also loosening the bolts holding the throttle arm down seemed to help and i gave the throttle cable a little more slack.
so on to the new problem.
my truck runs like a ford:bar f:
the mixture screw does nothing no matter how far in or out you take it. i think i have several vaccume leaks and i have no idea what needs to be plugged or left alone.
so any help would be appreciated once again
and thanks for the previous advice
Parker
some drunk guy
Aug 3, 2021 06:09 PM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
