relay wire kit for H4 conversion off ebay
Old Jan 8, 2009 | 09:58 AM
regularjoe's Avatar
We have been talking about the lighgts on ebay> I was thinking of getting a set with the 100/90 watt bulbs after i get the refund form the ones returned.
I wanted to run a relay for the lights. I looked at the one from summit and I found this one. http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
What you all think?
Old Jan 8, 2009 | 10:22 AM
Belize Off Road Team's Avatar
You shouldn't need a conversion kit for 100W only, i run 80/100W Hella bulbs on my stock wires with no problems.
Old Jan 8, 2009 | 10:26 AM
Tofer's Avatar
Sponsor
that looks alot like 4crawlers wiring harness....
Old Jan 8, 2009 | 10:43 AM
Elton's Avatar
if you do get that your prob gonna have to do a little rewiring since your truck uses switched ground
Old Jan 8, 2009 | 12:52 PM
regularjoe's Avatar
Toylo posted a shortcut to 4crawl on the other post. I would rather buy from them. I don't completly understand wiring so I don't understand switched ground. Does that mean the switch gives it the ground and the hots are always there?
Ok just read throught all the info on there sight I get it a little better but still don't completly understand. I can see that the hots are not always there It seems to me that they are always grounded. Sorry I just don't completly understand.
Old Jan 8, 2009 | 01:32 PM
ovrrdrive's Avatar
14 gauge wire isn't much - if any - better than the stock wires. The only benefit would be the shorter run to the battery. If I was making my own harness I'd probably use 10.
Old Jan 8, 2009 | 01:48 PM
4Crawler's Avatar
For switched ground, the headlight switch grounds the low or high beam filament to make it turn on, there is always power to the lights. There is special circuitry needed to make the high beam indicator on the dash to work right:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
- http://www.4crawler.com/4x4/CheapTri...shtml#TechInfo
Old Jan 8, 2009 | 05:01 PM
regularjoe's Avatar
Thankyou. That is the page I was reading earlier. If I get the lights and need this Ill let you know.
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Kytowboater
Sep 17, 2015 11:17 AM
Rawwdz
Sep 6, 2015 09:03 PM
