Out of Ideas!!
Old Jan 9, 2009 | 11:06 AM
4RunnerKat's Avatar
Out of Ideas!!
Ok, so my '94 4Runner has a speedometer out, I've changed the sensor (twice), checked out the cable (electronic), and taken apart the dash to find that everything looks good there. Still, no progress, I still have a non-working speedometer, and fear that it may be a bigger problem regarding the computer. In any case, anybody got some ideas as to where to go from here? I'm not sure if it'd be worth it for me to spend a ton of money on the vehicle since it being so old and has high mileage on it, but I would like to keep it around. Thanks guys!
Old Jan 9, 2009 | 11:11 AM
eighty5yota's Avatar
cheapo aftermarket speedo from kragens?
probably 100 bucks and will get you by.
my $0.02
Old Jan 9, 2009 | 11:12 AM
DeathCougar's Avatar
What do you mean "eveything looks good" in the speedo? Have you tested it, or replaced it?
Old Jan 9, 2009 | 11:20 AM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
talk to the 'Cougster 'bout a new inst cluster
Old Jan 9, 2009 | 01:16 PM
thook's Avatar
As Cougmeister implies, you can't always tell if an electro speedo is good or not just by looking at it.
http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
You'll need to jack the rearend up to run the test.
If you don't find a problem there, then look at the ECU.
corey519
Aug 12, 2015 11:12 AM
Up&Down
Aug 11, 2015 10:04 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
Sr5crawler
Jul 31, 2015 12:32 PM
PlayAwhile
Jul 20, 2015 11:36 AM
