Manual locking hub noise
Old 01-15-2009, 06:12 AM
vermontoyota's Avatar
Hey,
I have DIY hubs, which I like unless its -10 like it was here this morning and I cant get it out of the spot in 2wd.
I noticed that sometimes, after locking in, i hear noise in coming from the front when rolling that sounds like "wwwwhhhhommm wwwwhhhhhommm wwwwhhhooomm increasing in frequency with speed until road noise drowns it out (or it stops, can't hear it over 10 mph regardless). Seams to do it in 2wd and 4wd if the hubs are locked and doesn't seam to be much of an issue after shes been locked for a while
Anything to worry about??
Also- when shifting into 2 and 3 a can hear/feel a little click. Its not rough, it goes right in and is very smooth. Its less of a hesitation than it is just a slight noise. Truck only has 70,000k on it (everything, tranny motor body) but carfax says it was registered commercial for the first 10 years of its life so maybe some a-hole plowed with it.
thanks for any input.
Old 01-15-2009, 06:22 AM
waskillywabbit's Avatar
Time to do some maintenance on your wheel bearings and manual hubs.
Old 01-15-2009, 06:54 AM
874runnersr5's Avatar
Sounds like your spindle bushing needs some grease
Old 01-15-2009, 08:23 AM
87-4runner: are there fittings down there somewhere??
waskillywabit: maintenance in terms of what? grease?
Old 01-15-2009, 09:39 AM
sadly no fittings, there is this one tool that a guy on here made. Ill dig it up for you
https://www.yotatech.com/forums/f116...ctures-100327/
Old 04-08-2009, 09:28 AM
To the OP:
Please follow some of the suggestions already given above instead of starting another thread on the same problem.
Thanks.
Old 04-08-2009, 09:30 AM
TOYOTA 1's Avatar
x2....
deepmarsh
08-06-2015 03:44 AM
PlayAwhile
07-20-2015 11:36 AM
Steven.m.paulk
07-13-2015 01:40 PM
Poncho0206
07-10-2015 06:21 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Manual locking hub noise
