- cost efficient way to regear?
- Engine blocks compatible
- Let the rust repair begin
- Rusty fuel pump bracket removal
- Headers???
- quick question
- 93 3.0v6 MOTOR HELP
- Knuss says hello !!!
- 91 22re not runnin right
- Painting driveshaft- any balance problems?
- got my lift on(PICS!)
- fireing order ??? 94 22re
- before and after
- Detroit lsd(s) or Lockers; either with 5:29's
- rear diff. fill bolt welded..
- 22re Rough Idle
- overheating/engine temp problems
- Rubbing Tires
- 3rz Input...
- Marlin Crawler Shifter Seat Problem
- Tranny Oil
- Time to get my 4rnr out of purgatory!
- 7.5 or 8.0 diff???
- just bought :D
- Big Toyota Turbo!
- 93 3vze question- how to buy Auxillary Air Valve separately?
- What sensor is it? Or is it??
- Something's Wrong, please help
- Forward fuel line part number?
- brake drum rubbing on backing plate
- clutch gone or shifter seat?
- 2 piece drive shaft conversion?
- Speaker Location - 90 runner?
- total failure.
- frustated
- New OME Coils
- Brighter dash light bulb?
- Exhaust clip Thread
- 87 to 89 diff swap
- rich exhaust
- Pro Comp Shocks
- Clutch / Tranny... oi.
- Timing chain help?
- 6'5 in a reg cab
- Need ECM for a 94 Pickup- V6 5-Speed
- What does this sound like to you?(video)
- noisy-properly adjusted tappets
- questions about Chevy Springs
- ide screw...
- AfterMarket Air Intake Kit
- Noisy Cabin
- 4Runner head gasket went ---now for sale
- smoking after head fit 2L/TE engine
- 93 toyota not running right, HELP
- NEED 88-95 IFS front seal numbers.
- wires that are hot when engine is running
- 1987 toyota lift qustions
- Burnt Valve
- kinda odd...and seeminly impossible..IMHO
- clutch??????
- ***U joint woess ***
- BIG problem with BJ spacer write ups
- exhaust!!!
- Let's see how many things are wrong here
- Manual Trans swap...
- 22r/22re block question
- 1991 3.0 will not start
- TO rebuild or not to rebuild.. carb that is
- 22r engine recommendation
- 22-RE head gasket external leak question
- 2nd Gen rear seat in a 1st Gen runner
- 3.0 Vacuum lines pic request
- Mystery wire left over after my rebuild
- Hilux steering stabilizer
- check this thing out: 86 King cab Pickup
- Land Cruiser Muffler??
- Softer ride Anybody
- ARRGG!!! Misfires on 86 4Runner EFI
- LCE Header
- Water proofing manual transmission???????
- Shocks..
- Catalytic converter
- How to build a flatbed for <$30
- If you had $1300 credit at 4x4 shop would you???
- High Idle at start-up.
- tow hooks welded?
- tail light wire color
- 91' Extended Cab Rotors in 92' 4runner?
- wow this is wierd
- Amazing Find!!!
- coil spring booster
- E-brake! light
- wiper delay, jets stopped working
- Power Steering Leakage
- to rebuild or not to rebuild?
- Question & HELP! Ive searched already!!
- Moog coil spring vs Airlift 1000
- drivetrain seals
- 92' 22re code 43....Help!
- Pistons and Cams
- 87 head swap
- Some recent work done :)
- AC idle up mechanism- on board air
- 32,33" Fit Stock 4runner
- Got all my pics, New paint and extras..
- Weird Acceleration
- help
- 4 whelin with turbo?
- Grinding when turned full locked to the left
- Rear Differential Question
- Connector to Sensor
- Fuel Sending Unit Wire/Connector
- turbo a 22-re?
- Edelbrock 20158 or Pro comp shocks
- Thanks Dirtoyboy
- How heavy is a short bed?
- how to sepperate the transfer case from the transmission
- wish me luck
- Transmission noise HELP!!!
- AFM testing using FSM
- oil leak update (old engine cleaner thread update)
- 3.0L ARP studs - part numbers
- High oil pressure, yet again
- Engine Rebuild
- A/C went out with no warning
- head work help
- another "just painted my truck thread"
- 22re and v6 4x4, is it same transmission?
- Hot Air Intake
- The wood getter got wood...(PICS)
- Medalist Mudking Ply rating?
- replacement engine
- does anyone have a vacuum daigram for 86 22re?
- fuel injectors leaking
- 22R Idle hunting
- My Yota is to live again...
- 91 toyota 22re
- 3.0 EGR Removal and Idle questions
- 22re PS belt tensioner part sequence
- tire carrier from 4runner to pickup?
- 22-re engine mods?
- Where does the wire on the starter go to?
- 90 3vze runs horrible
- Why does my 86 Ex cab have a defroster switch?
- new or rebuilt carb question..
- Anyone know where to get fiberglass rocker pannels?
- What "brand" electric fan to use?????
- engine cleaner
- Hot Start Problem - How to test Igniter ?
- 86 4 runner interior and rear cargo lights not working
- 90's 4runner on to a 84 p/u?
- Help broken water pump bolts.
- could you help me out?
- 91 New radio... starter sounded slow... now won't start
- Fixing up my exhaust (on the cheap?)
- front and rear lockers?
- What to do.. what to do...
- 22r won't idle below 1500rpm, dies...
- NEED HELP!! Broke off plug
- 1UZ swap questions
- Rear and front sag?
- Rebuilding a 3.0
- any good boneyards in So Cal...
- clutch slipping?
- I sold my truck!! What a sad day!!
- exhaust through rear window
- Exhaust leak.
- block changes
- Code 11 help
- 33/10.50 BFG all-terrains on 1st gen 4Runner
- 1986 toyota brake help
- Code 51 Help
- wheel spacer debate....
- Wanted: Sliding rear window Latch
- valve timing issues
- fuel problem
- Grill guards widths
- cool looking euro lights for 90-92
- Truck Got Painted!!!
- Super charged 3.4 finally Pic's included
- Installing add-a-leaf..help?
- 1987 Pickup What now?
- good price?
- Need some Help! 93 runner
- Not Getting Fire to the Plugs
- NEEDED: Scrap ECU for '93 2WD
- 88 runner auto with 99 runner rear end?
- 22re complete engine price?
- 22re EGR block off
- 91 4runner wont turn over?
- Loose Water Pump Bolts - Replacing Fan Clutch
- fuel filter: how long does it take to change it?
- main bearing noise
- Oil Pan swap? Another option?
- 22RE Valve adjusment? Can a novice do it?
- FJ80 Wheels on First gen 4runner?
- Need exhaust pipe advice.
- body lift kit
- Did some painting.....
- Gearing
- 95 auto to manual swap question
- Sputtery start?
- Everything at once?!?!?!?
- Cheap, easy 4runner mods/maintenance/projects
- leaking coolant
- im bored.. lets get some thoughts. dropping a prius engine in p/u or 4runner
- Cheap way to kill butt sagg and a sound system question
- ...staying ahead of a problem
- Help With Homework
- transfercase removal
- Headers
- My Rig, #5 OFF PRODUCTION LINE
- front end noise
- 32x12.5x15 BFG AT questions
- Rocker Pannel Replacement
- need a little help
- stumbling and dying 3.0
- 93 'Yota truck fuel delivery system question
- Hub Dial bearing ?
- Codes 12 and 13
- Looking for a truck pic
- Need Help. Bed Bolts
- My 4runner started making a bad noise!
- Front end rebuild
- Looking to buy some tie rods
- My dash is falling apart.
- Infamous Question
- A 1987 van 4wd 4yec engine riddle..GOOD LUCK!!
- 3k rpm @ 65mph
- Hard brake line replacement - leaking brake fluid
- How do you guys fix that leaky top?
- Old 3.0 Chatter?
- muffler on the outs
- need help with 4x4
- alternator not charging!!! need help
- New Tires/Pics
- Redline MT-90
- Is my clutch any good? (pic!)
- Project 88 4Runner - So it begins......
- yay, new light installed today
- oil pump is leaking after head gasket changed
- Coolant Sensor Location
- dang, broken stuff.
- Just bought 86 4runner
- Rear Tailgate Function
- Uh oh. (lots of smoke)
- Where to find replacement bolts/nuts?
- What would cause a bad headgasket to just "go away"???
