oil leak update (old engine cleaner thread update)
Ok I think I found the leak and it's dang small so far.
It seems to be leaking from behind the crank pulley and from around the casing that's bolted to the front of the motor. I hope the pic helps.
Ideas? Is there a "front main" seal up there?
Jason thanks for all the schematics (spelling?) I can't count how many of these I've printed from you posting them.
So we're looking at what a 2 or 3 hour job to replace this little beast?
Anything else I should replace while I'm in there?
If the motor you are working on is the one in the pic, I would imagine it wouldn't be too difficult (never did it personally). If it's in the truck...well let's just say that would be a different story.
Looking at the manual, it looks like you will need the O-ring. Have you changed the oil pump already?
We did that on my girlfriends 95 22re runner.. The hayes manual said you need to drop the oil pan, which requires the diff to be dropped... WRONG!!
Its a pretty easy repair, just be carefull with the gears inside that pump...
Thats sig worthy
Its pretty straightforward. Though I can't remember if I drained the oil before I took it out or not....
Dang it...... Looks simple enough although probably time consuming.
The 4x4 and lifted trucks are easier to change as you can work from the bottom vs having to bend over and reach down from the top.
Don't forget to get the shaped O ring for the pump housing as you will be taking it off to replace the main seal. Good time for belts too as those will be off.
duckhead
170
Nov 13, 2017 06:07 AM
WI Girl
Jun 25, 2015 03:45 AM
