Grinding when turned full locked to the left
Old Sep 16, 2008 | 07:15 PM
chrisbnaz's Avatar
I haven't had a chance to really crawl under and check it out (At work), when I turn my wheels all the way to the left like while turning theres a nasty grinding sound. I glanced real quick when I got to work and didn't see anything obvious, cv's look fine etc..
Any ideas what I should look for tomorrow when I have some time to crawl under there and check things out?
Old Sep 16, 2008 | 07:17 PM
881stGenRunner's Avatar
maybe wheel bearing? sway bar endlinks worn? i really dont know. just throwing stuff out there for you to check
Old Sep 16, 2008 | 07:21 PM
chrisbnaz's Avatar
swaybar is gone
Old Sep 16, 2008 | 07:24 PM
awesome, mine is too. haha, eliminates that
Old Sep 16, 2008 | 09:27 PM
space-junk's Avatar
as in disappeared or what??? pardon me for being nosy, but could you take a pic so i can see what it looks like when you loose ove?
Old Sep 16, 2008 | 09:32 PM
mastacox's Avatar
My guess is its your steering stop. Looks like this:
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Sep 16, 2008 | 11:19 PM
chrisbnaz's Avatar
what?
Old Sep 17, 2008 | 09:30 AM
space-junk's Avatar
nevermind... i mesread your posts... lol... i thought you said that the swaybar being gone was the problem... D'OH!
Old Sep 17, 2008 | 09:33 AM
Matt16's Avatar
Steering stops. You can put grease or anti-seize compound on them, the latter lasts a couple months, the grease lasts a couple weeks.
Old Sep 17, 2008 | 10:01 AM
schmooot's Avatar
my wheel hits the mudflap at almost full left and grinds then at full left it hits the swaybar there
Old Sep 17, 2008 | 10:06 AM
saitotiktmdog's Avatar
What happens whe you turn your wheels all the way to the right? CV joints my look ok but may still be bad. What you are describing is how you can actually tell when your cv joints are bad. Go into a parking lot and turn the wheel untill is stops and then drive in circles. Unless it is your tires rubbing your wheel wells I would bet that it is the cv joint.
Old Sep 17, 2008 | 10:09 AM
mastacox's Avatar
I'm tellin ya, it's the steering stop. Easy fix.
Old Sep 17, 2008 | 10:50 AM
That is possible but to me it does not sound like a grinding but more of a loud popping/squeaking and is not real bad on a flat even surface. You really need up and down wheel travel while turned to full lock to really notice this.
Old Sep 17, 2008 | 10:54 AM
green91runner's Avatar
I've experienced this problem myself... I had both problems... the easy one was the steering stop (like shown in mastacox's pic), used some heavy grease like matt16 said, the other was one of my CV axles was going... so I replaced that. Tada, no more noise. Try greasing the stops first like mentioned above, and if you still have noise, look at the CV axle.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
mengquis
Jul 13, 2015 10:39 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
AaronM
Jul 8, 2015 07:15 PM
