tow hooks welded?
Old Sep 17, 2008 | 03:05 PM
DupermanDave's Avatar
tow hooks welded?
My hands hurt. After pushing and pulling the ratchet and breaker bar for about an hour I gave up. Are the bolts on the tow hooks welded onto the truck? Or glues or soldered or something incredibly overkill? We have a pneumatic air ratchet for our air compressor, but I don't have the proper downsizing socket adapter for the 17mm socket.
Old Sep 17, 2008 | 03:07 PM
tc's Avatar
tc
Nope, but they get REALLY rusted being all exposed to the elements like they are. Fortunately, they're pretty strong bolts so you don't have to worry much about breaking them.
PB Blaster or similar and a LONG cheater bar.
Old Sep 17, 2008 | 03:22 PM
red97taco's Avatar
X2
If you have a jack, take the handle off of it and use it as a cheater bar.
The air ratchet wont work anyway....not enough torque.... but an impact would help
Old Sep 17, 2008 | 03:28 PM
Arrg. Hand hurts. Now way I'm getting that off as-is. I don't have a cheater bar around, I'll have to get that tomorrow. I sprayed penetrating oil on it and it didn't help. I looked at the other hook and it did look like it was soldered or welded on, but that could just be from corrosion.
Old Sep 17, 2008 | 04:09 PM
jason191918's Avatar
Fire Wrench!!!!!!!!!!!!
Old Sep 17, 2008 | 04:13 PM
fillsrunner4's Avatar
are you sure your not tightning the bolt get a decent breaker bar one there and if you need a bit more leverage get a pipe to put on the end of it. they are not welded
Old Sep 17, 2008 | 04:27 PM
SwampThing's Avatar
x2 on the victor/blue wrench.
Old Sep 17, 2008 | 04:28 PM
Noltz's Avatar
Whip by a garage with $10 and a coffee, and ask one of the mechanics to loosen the bolts for ya. It's just not worth bruised palms for a week.. ya know?
Old Sep 17, 2008 | 04:45 PM
Totally agree. Yet, the bruised palms would be a badge of accomplishment.
I have no bars around to aid the situation, so I'm going to swing by Lowes for one. It'll be good for the future.
And yes, I'm 100% sure I'm not tightening it. I'm new to cars, but not mechanical engineering.
Old Sep 17, 2008 | 04:46 PM
Mic09dcsm's Avatar
Go to the gym, or befriend an Igor.
Old Sep 17, 2008 | 05:37 PM
Chapman88SR5's Avatar
Do not under estimate the power of a long cheater bar! I'm talkin at LEAST four feet here.
Old Sep 17, 2008 | 05:39 PM
MMA_Alex's Avatar
pb blaster & heat
get it nice and hot, and put on a 6pt socket, and a 4 ft cheater bar, and have someone hit the end of the bar with a sledge hammer...works every time.
I had to do that once for a lugnut that I couldnt get off with a 400 ft/lb impact gun
Old Sep 17, 2008 | 05:57 PM
bigtrucknwheels's Avatar
Look, I am a huge dude, and I go to the gym, but I can show you some bolts that will defeat an Iron Man without a cheater bar... come work on my runner, I dare you...
+1 for the Igor
Old Sep 17, 2008 | 06:01 PM
Beaniam's Avatar
I broke 2 of the bolts on one side getting mine off and twisted the other 2 nuts free that are welded inside the frame. Ended up cutting those off with a grinder.
Old Sep 17, 2008 | 06:05 PM
SwampThing's Avatar
+1 for the Igor
Yes but can you speak with an austrian accent? I got ya beat there hoss
Why not just do the two wrench cheater trick?
Old Sep 17, 2008 | 06:10 PM
I can do British/Boston/Italian, but not Australian... you got me I guess.
Old Sep 17, 2008 | 06:14 PM
Mic09dcsm's Avatar
Lol, Dude, Austrian as in Hitler's homeland, south of the motherland.
Old Sep 17, 2008 | 06:23 PM
I can do German. and I can't believe I missed that... I am not even sure of an excuse to use for that...
Old Sep 17, 2008 | 06:56 PM
Originally Posted by MMA_Alex
pb blaster & heat
I was actually going to try that. I was going to heat it up with a cigarette lighter (I don't smoke, but I have a lighter around just in case...fire is fun )
I also thought about using the lighter to heat the surrounding metal and ice down the bolt so the metal around the bolt would be expanded and the cold bolt would shrink.
Old Sep 17, 2008 | 07:05 PM
SwampThing's Avatar
Man... Come on... GET TO THE CHOPPA!
Ring a bell? Maybe?
What about the GOVERNATOR!
No?
