tow hooks welded?
Old Sep 20, 2008 | 12:40 PM
  #41
MMA_Alex's Avatar
as long as it drills out easily...Ive always found that its easier to remove it, than to drill/cut it out
Yes the torch, and pb blaster will run somewhere around $30, but if you wrench on an older truck you'll find out that a lot of the bolts need a little help coming off, and a torch, and pb blaster are your best friend.
Old Sep 20, 2008 | 07:27 PM
  #42
DupermanDave's Avatar
I guess that's true. It'll be an investment.
Old Sep 20, 2008 | 07:36 PM
  #43
tc's Avatar
tc
I have never had good luck drilling out bolts and then reusing the holes - the bolt is harder than the surrounding material, and the drill never wants to stay in the bolt...
Old Sep 21, 2008 | 04:41 PM
  #44
aviator's Avatar
TC is right your chances of successfully drilling out a bolt like the kind used to hold on the towhook are between slim and none those bolts are grade 8 and they just won't drill [especially trying to drill straight up with hot shavings spilling down on you]. PB [or similar product] a torch and a big breaker bar are your best options.
Old Sep 21, 2008 | 04:44 PM
  #45
bigt's Avatar
its what big rig diesel mechanics use!
RyanJ989
11
Apr 7, 2021 09:41 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
VT2LAB
Sep 10, 2015 09:36 AM
mirabile4runner
Sep 3, 2015 07:15 AM
