2 piece drive shaft conversion?
Old Sep 20, 2008 | 11:24 AM
surtur's Avatar
Hi guys i have an 89 extended cab 4x4 toyota truck what i want to do is drop the 2piece drive shaft and get a 1 piece installed.
the problem is cost i talked to my local drives shaft shop and for them to make me a custom 1 piece it would be around 7-800$ what i am wondering is if i could get a drive shaft from a Chevy truck would a shop be able to lengthen it a couple inches and put new flanges on it so it would adapt to my toyota??
has anyone tried this or would it be to weak? i only have a 22re in my truck so not a whole lot of power..
the reason i want to do this is for some reason my center or steady bearing (the one that keeps the 2 piece from twisting in half keeps going after around a year and i end up twisting my drive shaft off and banging it around.
and these bearings are around 350$ from my local shops.
any help or suggestions would be great.
Old Sep 20, 2008 | 11:29 AM
mt_goat's Avatar
Wow, I'm still using my original. Something must be wrong
Here's a write-up on making the change though:
http://www.4x4wire.com/toyota/tech/driveshaft/
Old Sep 20, 2008 | 11:35 AM
surtur's Avatar
thanks for the quick reply i think something is miss aligned or i just have bad luck with faulty bearings.
Thanks for the link that is actually were i got the idea but lost the link.
i just want to know if i can use an old chevy or similar drive shaft and have it modded to fit?
Old Sep 20, 2008 | 04:12 PM
mt_goat's Avatar
If your u-joints on both ends are good, you might be able to have a single tube made at a drive line shop.
andrewtexas123
Jul 14, 2015 04:29 AM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
akaphilly
Jul 9, 2015 02:34 PM
Jnkml
Jul 6, 2015 01:20 PM
