Help broken water pump bolts.
I'm doing the timing chain on my 22RE and three of the bolts that hold the water pump on broke off during disassembly. I got two of them out of the timing chain cover and i am working on the third.
Where is a good place to get new bolts for the water pump? I am going to replace them all.
Can i just go to my local fastener store and get some or should i go to the stealer?
If you get them from the local hardware store, make sure they are the EXACT same length, or you can push through the timing cover and create a hole. My recommendation is go dealer, since its the same price and you know they are the correct length.
So I went to the dealer to get the parts, the price was not that bad.
Now the only issue I have is getting the oil pan to drop out.
I removed the 3 bolts that hold the Front diff up and the steering linkage bolts. Everything is out of the way, but the diff didn't drop far enough down.
Do I need to take the drive shaft bolts off too?
Is there anything else I can do to get it out?
I unbolted the front drive shaft from the diff and the pan came right out.
When I picked up the bolts for the water pump from the dealer three of the bolts turned out to be studs. Where do the studs go? All the fasteners I pulled were bolts. The dealer said the PO must have swapped them out.
