total failure.
Old Sep 20, 2008 | 09:19 AM
Junkers88's Avatar
total failure.
I decided to do the front main seal this morning and wait to do the timing chain and other things until I've got more time and a little more confidence.
The result was a complete failure on my part. I got everything taken apart and out of the way so I could get the crank pulley off and then couldn't even get the dang crank bolt off. So I put it all back together and took the parts back. Good news is that I don't think I messed anything up, well other than having to cut the AC belt to get it off, but now I have a whistle that sounds like a turbo spooling up when give it fuel. Strange but it sounds neat.
I'm going to find a beer and contemplate my lack of knowledge on this thing. Heck compared to this swaping out thirds and installing a locker was a damn breeze.
Laters.
Old Sep 20, 2008 | 09:27 AM
4Crawler's Avatar
I use a 19mm impact socket and breaker bar laid over against the frame then bump the starter (disconnect coil wire) and it'll usually pop that nut loose:
http://www.4crawler.com/4x4/CheapTri...l#CylinderHead
Should not have had to cut the A/C belt, there is a tensioner pulley for that belt. Loosen the nut in the center of the pulley then back off the tensioner bolt and the belt should come right off.
Old Sep 20, 2008 | 09:32 AM
Ironmike4x4's Avatar
Only way to learn is do it and learn from your mistakes. My shop foreman will sometimes watch me and know I'm making a mistake but says nothing unless it's something that will really be costly. After scractching my head and finally figure it out my foreman will tell me a better or easier way to do a job. He's often told me if he holds my hand then I won't learn anything so he allows me to make mistakes first.
The noise could be anything... alternator bearing going out, waterpump, p.s. pump. Just try to locate the noise more specifically and fix it from there. Good luck.
Old Sep 20, 2008 | 10:08 AM
wardriver's Avatar
X2
Also used breaker bar with a piece of floor jack handle to gain enough leverage....starter trick is way easier.
Old Sep 20, 2008 | 10:59 AM
scuba's Avatar
beer..at 10 in the morning...well i guess its 5 o clock somewhere
Old Sep 20, 2008 | 11:13 AM
forbiddenera's Avatar
breakfast beer is awesome
Old Sep 20, 2008 | 11:16 AM
scuba's Avatar
Ill have to try that soon !!
Old Sep 20, 2008 | 12:43 PM
Junkers88's Avatar
I've got the socket and a 4 foot breaker bar, just moved the truck down the driveway while I pulled on it. The starter bump thing makes me a little "loose in the bowels" if you know what I mean. I don't want to shatter anything as this is my only vehicle.
I relaxed the A/C tensioner to the point that I removed it and still had less than an inch of play between the compressor and the water pump pulley, old belt that would not come off no matter how I pryed on it.
Man 4Crawler I feel like such an ass for not being able to do this on my own. Everything I've tried on this rig has gone off without any problems at all. I just figured today would be the same. You have no idea how bothered I am that I couldn't get this done on my own.....
Old Sep 20, 2008 | 12:48 PM
Junkers88's Avatar
Sometimes you just have to step back, crack a beer and realize you're in over your head. It gives you a chance to think without destoying your rig.... and get "Swampthinged" in the process.
Old Sep 20, 2008 | 01:02 PM
4Crawler's Avatar
The starter method works flawlessly, if you prefer, think of it as an "electric impact wrench". I fooled with mine by hand, then first one old and then a new 1/2" impact and nothing was happening. I did break one socket (it was old) trying to remove that nut, but nothing other than it split on the end and fell off the nut. New socket and off it came with just a flick of the key.
But if the truck is moving, put it in 4H and 4th or 5th gear (lower gears make it easy for the engine - or you - to turn the wheels, you want to make it hard to turn them), e-brake on then put some blocks in FRONT of the tires. Then it should come off with your breaker bar.
Old Sep 20, 2008 | 06:00 PM
annoyingrob's Avatar
If moving the pulley bolt is just moving your truck, stick the damn e-brake on. If your e-brake doesn't work, chock the wheels.
You'll want a gear puller to pull the pulley off once you get the bolt loose too.
Old Sep 20, 2008 | 06:21 PM
BigBluePile's Avatar
It is possible to get that crank pulley bolt off without using the starter if you are that worried. Like was mentioned, put the tranny in 4th or 5th and lock the hubs and put it 4hi. Then take a stick and jam the brake pedal all the way to the floor to hold it there. No need to set the ebrake because now you have front and rear brakes holding. Use a 12 point 19mm socket and braker bar with a healthy pipe extension and it should break free just fine.
Old Sep 20, 2008 | 09:39 PM
Matt16's Avatar
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
