Tranny Oil
Old Sep 20, 2008 | 05:56 PM
94_yota_pickup's Avatar
Tranny Oil
What kind of oil does tranny and the rear end and front take?
Old Sep 20, 2008 | 08:26 PM
PCE91V64x4's Avatar
Plenty of opinions on this, but I use Redline MTL in the transmission and (I think) Redline 75W-90 everywhere else.
It is in the manual/FSM.
Old Sep 20, 2008 | 09:50 PM
DeathCougar's Avatar
Manual trans or auto?
Assuming you have a 5speed, i would say 75-90 anything will work just fine. I use Royal Purple in my Race cars (toyota MR2) and have yet to experience a problem.
Old Sep 20, 2008 | 10:01 PM
CoedNaked's Avatar
Amsoil Manual Transmission & Transaxle fluid 75w90 (GL-4) for my transmission & Amsoil 75w90 longlife Synthetic Gear Lube (GL-5) for everything else (Transfer case, Front/rear diffs). I could also use the Transmission/transaxle fluid in my transfer case if I want as I believe it can take either a GL-4 or GL-5.
Next gear oil change I'll probably be putting Amsoil Manual Transmission & Transaxle fluid 75w90 GL-4 in my Transmission & transfer case, and Amsoil 75w90 Severe Gear in my Front & Rear Diff's.
Old Sep 21, 2008 | 05:12 AM
blaiwayw's Avatar
Second the Amsoil selection. Do a comparison on the different lubes. Living in Montana (gets to -25 occassionally) I want a lube that actually stays fluid at extreme temps. You can order direct from Amsoil. For $10 become a dealer for 6 months and the discount will more than cover the shipping. I needed 5 qts of each (GL4 and GL5) to fill the differentcials, transmission and transfer case. Cost under $100. Pricey, but good product.
Old Oct 8, 2008 | 09:52 AM
yukon6inchlift's Avatar
sooo, me being a cheap ass and dont want to spend more than i have to,,,,i can get by using regular 80w-90 in my trans, tcase, and diffs?? 81 manual 4 speed thanks
Old Oct 8, 2008 | 11:45 AM
4Crawler's Avatar
GL-4 in the manual transmission, GL-4 or 5 in the t-case and GL-5 in the axles:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Fluids
Old Oct 8, 2008 | 11:59 AM
22mr2's Avatar
I stepped up to synthetic a few years ago and have a much easier time shifting when its cold. 75/90 valvoline. The only downer to synthetic is that it always seems to leak more
Old Oct 8, 2008 | 12:55 PM
Squeebs's Avatar
Amsoil severe gear front, transfer, and tranny.
rear diff leaks so i just put whatever i have laying around to top it off.
Old Oct 8, 2008 | 01:54 PM
iamsuperbleeder's Avatar
I just put in cheap stuff right now
after my recent tranny-fluid change, I don't know how long the trans is going to last n-e-way (see here), so I just put generic brand 80w90 in it, and 75w90 in the t-case. Just fixed a leaky rear-diff gasket and put the same in it, cheapo 80w90, but it'll be getting re-geared and locked in the near future (along with the front diff), so I'll be putting the higher-dollar stuff in it when that time comes.
after asking the same question here on YT myself in the not-too-distant past, I'm probably going to go with Redline, because so many people highly recommend it
Dieselmann
Feb 19, 2019 02:57 AM
yourrealdad
Jul 29, 2015 11:08 AM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
