questions about Chevy Springs
I wanna put 63'' chevy springs on my yota. should i straight axle it first or save money keep it ifs.
i have a 5inch suspension lift already iwanted to add thechevy springs with that and get 35's. along with 4:88 Gears.
Anyone give me ideas on what to do and how to do it.?
Please anything will help. im a teenager with big dreams.
I would say do the chevies now and save up for the SAS. the chevies shouldn't cost much and will still work with the IFS and flex mad!!
I dove into chevies rear and RUF on my 84 and i have been busting a$$ to get it done and i wish i could have done it in steps so i could tune the rear first then the front instead of going out with all new susp.!!
but you can do it i did my chevy rears in 18 hours, but i had to plate the frame majorly because i ripped the old spring hanger off!! and i fabbed every bracket from scratch so that added some design time.
Thanks alot for your help
Do the Chevy's first then you can reuse your existing rear springs on the front save $$$. Before you take anything apart, make sure to get the 9/16 bolts out of the Chevy springs first. That can take a while with penetrating lube and a BFH. After thats done plan on replacing the marshmellowed out factory 9/16's inch bolts with new grade 8 bolts. You might as well get energy suspension poly bushings for the Chevy's too, especially if you need to use heat to get them apart.
Good luck on the swap, it's an adventure.
no you are right regear is definately worht the money if you can afford it, and personally i would go with 5.29's after you SAS no matter what tire you run
Just throw some 28's on there afterward, 4WD burnouts FTW! lol
unless you go over big huge rocks, a SAS will probably not be near as beneficial to you as lockers/gears.
also, SAS should be one of the last things to consider. lockers and gears, armor, tires and lift, in that exact order, above all else, if you are really serious about wheeling. if you want to mall crawl (which is perfectly fine, 99% of my Jeep buddies are that way), do the lift and tires and forget the rest.
good luck!
priest16
15
Aug 6, 2015 07:43 AM
defrag4
Jul 31, 2015 10:50 AM
coffey50
Jul 28, 2015 10:55 AM
