PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 [173] 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. home made "CBI" spare carrier
  2. Tellico with IFS?
  3. whining sound
  4. Correct me if I'm wrong.....please...
  5. Fuel filter not 'normal' replacement?
  6. corrosion
  7. Bilstein, OME or Doetsch shocks and why...
  8. A Variety Hour!
  9. Auto to Stick Info?
  10. Best donor vehicle
  11. no power in 4 & 5 gear now
  12. No Battery = No Neutral????
  13. 87 runner, take a look and offer advice
  14. 1994 3.0L 4Runner engine woes...
  15. Does 86-89 heater cores fit my 90 4runner
  16. Tough question on A340F
  17. Answer this and win a prize for most obscure knowledge...A340F
  18. 1994 4 Runner [Which Suspension?]
  19. Coolant leak in the back of 3VZE
  20. custom tow hook or something
  21. sooo i fixed my bracket problem
  22. won't shift into 4wd
  23. rebuilding the 22-re
  24. 3vze wont start now
  25. What size of diff do i have?
  26. What size of Diff do i have
  27. Died idling then no start
  28. the MAF on the inside
  29. 4runner just got Dune Buggy - I need help starting it, Youtube Vid
  30. My 2nd Gen Up and Running again after a Rebuild
  31. Need Help: Ton of white smoke out of the exhaust, wont start
  32. 92 v6 ADD front diff help
  33. Topless 4runner owners
  34. Gas Leak! Give me an answer and win a prize!!
  35. 89 p/u rear spings HELP
  36. HELP! Bracket questions!
  37. Looking for a radiator. prices? blacklists?
  38. Tomorrow's the big day...
  39. Someone PLEASE HELP.. solenoid problem...
  40. What modifications should I let the Gov't pay for?
  41. Carbon build up
  42. VF1A Transfer help
  43. 3slow fuel pressure regulator
  44. disable drl on a 93 pickup
  45. Anyone help dial in a freshly installed cleaned carb???
  46. exhaust question.
  47. My truck can't be that slow!
  48. Strange clutch problem
  49. Ardent's "New" 88 4Runner
  50. 86 sas
  51. Should I stay flat..
  52. 1991 4runner 3.0L auto ISSUES
  53. hard to start
  54. Coolant Overflow Tank
  55. doing a rebuild best way to increase power?
  56. my transmission fluid keeps changing levels on the dip stick
  57. 22re mods
  58. driver passenger seat cushions swap
  59. HELP!! Engine and Transmision
  60. 1994 4Runner SR5, Bad ECT (Coolant Temp Sensor)
  61. 90 3.0 engine went. Info on swap
  62. Rear inside side panel simple question
  63. lift queastion
  64. Crap! oil everywhere...
  65. frustrating high idle issue
  66. Alright once again, but for clarification
  67. wheel studs!!!!
  68. 22re started squealing, now no start
  69. Which color wire to which trans. solenoid?
  70. need some help - 1989 4Runner
  71. Steering work, help needed.
  72. Engine Swap
  73. '87 4x4 truck 22r vacuum advance question
  74. High Compression Numbers
  75. 92 yota questions
  76. Urgent Advice/Opinion Regarding Buying a truck today
  77. regearing my 94 pick-m-up truck
  78. bent bumper. repairable/worth it?
  79. LOTS of Vibration and a little shaking?!
  80. '94 Truck Stalling Out Randomly
  81. Spider gears?
  82. Need help with code 5 on my 87 4 runner 22re
  83. Time to re-gear or not?
  84. Will a Ford Festiva afm work on my 3.0???
  85. wont stay running
  86. Brake system problem please help
  87. 4runner and p/u tailgate swap?
  88. custom air filter setup
  89. what should i put on my grille?
  90. A few questions on 22R-TE temperature sensors
  91. Fresh Paint
  92. Clicking/Knocking When Turn Sharp
  93. 3vze timing belt - need help
  94. Rear window works when you push or beat tailgate.
  95. Toyboy to the rescue
  96. fresh rebuild 3vze having a couple problems need help
  97. 87 22rte NO start after rebuild!
  98. Torsion Bars?
  99. Opinion? Cracked Exhaust manifold?
  100. So i have decided to finaly fix my sag!
  101. 91 Camry Intake.......Finally
  102. a long last...
  103. Harbor Frieight Engine Mount Bolts
  104. Problems!?!?!VERY bad week
  105. missing plug off egr
  106. Lift kit and 33: Installed
  107. Are the beds on 3rd gen 2wd and 4wd p/u's the same?
  108. Good cams?
  109. I am confused, please help.
  110. 92 pickup not running. why?
  111. Waterless antifreeze, I use it, anyone else?
  112. More travel out of IFS?
  113. water went down dipstick hole
  114. 22re power loss (long)
  115. How much Pag and 134a for my AC?
  116. Allignment parts replacement question
  117. Fairly new to addin mods to the 22re
  118. Problem
  119. New type-r guitar!
  120. Air Conditioner Specs question
  121. Help! Need Advice!
  122. Emissions Check, expect?
  123. witchhunter versus BG44k
  124. Pics Of K&N Intake Kit
  125. tachometer install help (pic included)
  126. FiberGlass Cowl Hoods!!
  127. '90 "Loaded" 4Runner For $4,000...What Do you Think?
  128. Warn Install in TJM-T15
  129. '91 ADD wont engage
  130. 1990 4Runner in Medium Brown Metallic?
  131. 22re mufflers
  132. charging problems (alternator wiring?)
  133. The mystery internal coolant leak
  134. ABS Diagnosis Issue
  135. swap Help
  136. Wiring Diagrams/Color Codes?
  137. Shady work at the dealership... no happy!
  138. Just picked the truck up after a head gasket job
  139. Weak performance under 3k rpm
  140. Windshield knocking sound at high speed
  141. what is wrong???
  142. 90 pickup firewall issue..
  143. 3.0 Stalled Won't Start No Spark
  144. Choices For Starters
  145. !!!Bet you can't figure this one out!!!
  146. Bet you can
  147. 94 leans to one side WHAT HAPPENED?
  148. High Idle when cold 22r
  149. Mic's 1990 Toyota pickup
  150. 3 day blitz ....
  151. Toytec 2" before and after
  152. Think I found my next project...
  153. cone washers on hub body
  154. o2 sensor testing question
  155. Pro-Comp shocks, whats the difference and which ones? HELP!
  156. Bumper -Powder Coat or?
  157. need a motor
  158. How do you adjust 4Runner for Colorado Elevation Driving
  159. New engine!!
  160. Hydraulic Throw Out Bearing
  161. 91 4x4 PU 6cyl questions
  162. Myth/theory of the 22re Cracked Block
  163. running rich o2 sensor?
  164. Truck keeps dying
  165. 22re break in
  166. 4x4 doesnt work
  167. NO SPARK AFTER H/G REPAIR... haven't heard this one have you?
  168. T3 or CT26 Swap?
  169. What headers do I have...
  170. 15x7 3.75 BS with 31x10.50r15.... got pics?
  171. I converted another driver!!!!
  172. Brake Problem???
  173. Hello....have a question
  174. Whats the best hi-flow cat? best preformance/sound
  175. Westin Ultimate Bull bar on 90 Pickup?
  176. Factory pedals, factory speakers
  177. Help! 88' yota or new tacoma?
  178. Power Steering Swap?
  179. Has anyone used a procomp 3inch suspenion lift?
  180. Rancho RS9000 shocks 4sale for a 3-4" lifted rig
  181. shock lengths / recommendations for BJ spacers and Downey 2” lift springs?
  182. quick breather mod question
  183. finished rebuild 3.0
  184. body lift troubles
  185. 88 3.0 head gasket job being done as I type this
  186. Clear front bumper signal lights housing on EBAY!
  187. HELP! Powder day and key wont turn!
  188. Got a delivery today!!!:D
  189. Crap... I think
  190. fiberglass tops
  191. R150F Upgrade
  192. which ct-26
  193. Compression problems 22 RE
  194. CV Joint change.
  195. Automatic Transmission question
  196. Steering Relay Rod Recall (PROBLEMS)
  197. Yotateachers, let me know if I just had an awesome idea (long post)
  198. Hi-Lift Jack doo hickey
  199. Inner Axle Tube (Rear)?
  200. rough start up/idle
  201. Rear Seat Modification
  202. Interior Firewall Insulation
  203. 89' runner, front end noies and longevity
  204. 88 4runner grab handle installation?
  205. Bump Stops
  206. 87 4x4 pickup fan turning on and off at high rpms
  207. Sway Bar
  208. Moving... need advice.
  209. Front driver side popping sound.
  210. Code 71 solved!
  211. how to clean egr stuff
  212. Highbeam reminder light- annoying? yes
  213. air filter housing swap
  214. Sensor ID on 1990 3.0 5spd
  215. S&B Filter? any good
  216. Carb Question
  217. R150F vs R154
  218. 3VZE question
  219. no start 22re...not frozen...
  220. Engine help. rebuild or run it?
  221. what should my compression be
  222. **%&!!!! my headgasket blew AGAIN!!! advice on rebuild?
  223. RS 5000 Rear Shocks
  224. 2wd BJ's! spacers that is lol...
  225. Help with temp gauge/sending unit
  226. What is wrong with my 3.0 engine??!!
  227. 22RE Oil Leak Help Please...
  228. 92 4x4 Advise on purchase
  229. Automatic Transmission Vacuum lines???
  230. best way to unstick a rim
  231. will this work
  232. alternator ??
  233. Truck runs great for 2 seconds. Please Help!!!
  234. 3vze going down
  235. Water Pump Replacement
  236. All-Pro vs. Trail-Gear vs ?? -- IFS Steering Box
  237. Rear lift
  238. Power Steering Hose Alternative.
  239. not starting -seems like fuel issue
  240. switching my automatic hubs to manual what do i need?
  241. 1994 4runner What To Know?
  242. Light Bars not lights on a roll bar
  243. 2wd v6 diff
  244. Flywheel/pressure plate bolts
  245. 3.0 0nly, Post your GAS MILEAGE!!
  246. Break Dust Covers
  247. Front Sway Bar Bushing (27mm)?
  248. body or suspension lift
  249. 2nd Gen Factory Sunroof Installation
  250. Engine Oil Cooler
