water went down dipstick hole
Old Jan 31, 2009 | 07:55 PM
gary96360's Avatar
i washed my engine today, after i was done i took off the bag covering the distributor and the dip stick got pulled a bit out, tiny bit of water went down about 3 drops, i quickly pressed the dipstick down. should i drain the oil or just leave it.
Old Jan 31, 2009 | 08:10 PM
Jay351's Avatar
If it was only 3 drops, I woulndt worry about it. But it can't hurt to change the oil
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
No biggie. It will boil off first time you run it. It could accumulate that much just cooling down during normal operation.
Old Jan 31, 2009 | 08:11 PM
Windsor's Avatar
Drain and refill is pretty cheap and quick. I'd drain, as well as try hard to flush the tube with oil. But I'm paranoid like that.
Old Jan 31, 2009 | 08:24 PM
superpeanutman's Avatar
three drops is nothing. take it on a long trip, get it running hot, that will fix it. if your paranoid, add some additives.
Old Jan 31, 2009 | 08:30 PM
gary96360's Avatar
i just changed my oil less than 2,000km (1,250miles) but im too cheap to change it. ive done much worse, my last truck i used a funnel to pour oil into it after i did it i looked into the skinny part of the funnel and i saw some dirt in it. i didn't even bother changing the oil. its sad that i care more about a few drops of water in my yota than dirt in a newer ram lol.
Old Jan 31, 2009 | 08:47 PM
rngrchad's Avatar
In cold weather the condensation that will build inside your motor creates more h20 than a few droplets of water. You'll be fine. Don't worry about it man. I've sucked gallons into my yota's and pumped it out the tailpipe. It's good to flush the system once in a while.
Old Jan 31, 2009 | 08:48 PM
rngrchad's Avatar
Yeh, no kidding your paranoid. It's your money, use it to line big-oil's profits a bit more and change your oil for the sake of the recession.
Old Jan 31, 2009 | 08:49 PM
aviator's Avatar
I would'nt worry about it... it's not like a little water in the pan is going to hydro anything lol and it will boil off before it will do any real harm... next change do a flush first and that will handle it.
Old Jan 31, 2009 | 09:09 PM
Windsor's Avatar
pshaw, not like you drive a Prius.
I was expressing the "when in doubt" clause. If OP was concerned enough to post up, might as well just flush it.
Old Jan 31, 2009 | 09:10 PM
rngrchad's Avatar
Chicks dig guys who drive prius's. I'm gonna sell all 3 yota's and join the priustech forums. Seeya!
Old Jan 31, 2009 | 09:14 PM
Windsor's Avatar
nice.
Old Jan 31, 2009 | 09:20 PM
rngrchad's Avatar
nice.
See I told you chick's dig prius's:
Old Jan 31, 2009 | 09:22 PM
Windsor's Avatar
What are the odds that those ladies are vegetarians?
Old Jan 31, 2009 | 09:25 PM
rngrchad's Avatar
I dunno, I'll ask them. I just met them on priustech.com They are coming over tommorow night to drive all my yota trucks to the stealership so I can trade them in on one prius. Yes, that's right, all 4 of them ladies will be riding back with me in my new prius. I'll post pics tommorow. Stay tuned.
Old Jan 31, 2009 | 10:38 PM
gary96360's Avatar
anyone know who set the standard for oil changes every 3,000 miles. that could also be a money making scheme by the companies lol
Old Jan 31, 2009 | 10:42 PM
gary96360's Avatar
i love the sight of a vehicle blowing water and coolant out of the tailpipe. i bought the truck with a blown headgasket and loved to drive it in short bursts around the neighborhood, creating a mountain of smoke and stink.
Old Jan 31, 2009 | 11:04 PM
Windsor's Avatar
Even better is the Mazda rotary engine with an apex seal not working (either stuck in the "down" (non-sealing) position or plain ol' worn out). The cure to get it started is a touch of ATF in the intake (carb or however you can get it in).
When the engine fires up, the car belches a nasty-smelling white smoke-screen that is guaranteed to impress your neighbors.
Old Feb 1, 2009 | 08:58 AM
gary96360's Avatar
i bet that a cop will pull you over if he/she sees it haha, especially in california.
Old Feb 1, 2009 | 11:18 AM
Jay351's Avatar
Uhoh... here comes the smug!! Gonna move to sanfransisco n start sniffin yer farts?
